another TBF project
#46
Take the oil pan off and inspect the bearings. The 1988 I am parting out had a blow headgasket, leaky radiator oil cooler and just now I found out it also spun two bearings.
#47
Shameful Thread Killer
Well since its a 5 speed shouldnt it be okay ? Im not sure but this test is done on Auto transmissions. Can the 5 speeds be prone to Trust-BF ?
As rod bearings go I would check 2 and 6 or just change them. I took 2 S4 motors apart and the 2 and 6 bearings had alittle more wear than the othere ones but they still looked to be good.
#51
Under the Lift
#54
Namasgt, i used a plastic bristle brush.
i did check the endplay several times and i got a measurement of .253 to .270
i'm thinking the max .40 but correct me if i'm wrong. i'm also gonna
check one more time with a helper tomorrow. i've included some pics of the bearings and the crank journal, some of them didn't turn out so good. let me know if you see something i don't. to me they seem good. would you change them anyway?
#55
If that's the 2/6 bearing it looks pretty good. The pics aren't very clear of course, but you can mic the journal to see what it's at. I think the crank and bearings are ok, but it's hard to see very well.
#56
yeah i know. i tried to take several pics but they wouldn't come out any better than these. the journal does look very good and the bearings not bad for 90k i guess. debating whether to just replace them now.
#58
Just a suggestion--do you have a "macro" or a "closeup" button on your camera? Looks like the closeups of the bearings are of poorer quality than first pic, which looks OK. Maybe that would help get some clearer pix?
#59
Fab an adapter with HomeDespot/Lowes plumbing parts, pressurize it with a MityVac, and see if it holds? One could even put a liquid in the chamber that would be forced past the valve (or not) under pressure. The liquid might make finding the leak-point of a non-obvious leak easier, though I'm not sure what good knowing that would do.
OTOH, there's that old surgeon's maxim that better is the enemy of good.
P.S. Pretty motor.
#60
