Leaking Radiator Side Tank
#46
#47
#49
P30 ? Not sure what that means. O-rings are measured by inside diameter (I.D) and cross section (C.S.). Are you saying you used a 30mm I.D. o-ring. Here's a source for metric sizes:
http://www.mdmetric.com/oring1.htm
#50
#51
http://www.herculescn.com/images/357358.pdf
#53
If that's where it's leaking, make sure you've got it tight. I replaced that small hose that attaches at the bottom of the cooler and it continued to leak. So I decided to try and tighten it some more. The leak stopped.
#54
Randy if the adapters are leaking you try to tighten them a bit, But I would remove the leakers and add some pipe sealant then install them.
I would think given the age of the car the hose connections where the crimps are are ptobably the leak points.
With this info i would also suggest that you inspaect the lines that go to the trans , usually you will see weeping, if you do then you should replace these flexible lines as well so you dont get a cat fire
#55
Can I cut the swage collar off and reinstall using a hose clamp as shown in the pic above?
#56
What I was trying to say was that we do not use O rings when we replace the coolers into the plastic end tanks. We use the flat rubber washers that come with the plastic end tank from Behr.
No O rings were hurt in the installation of our plastic tanks and coolers.
AFAIK the original seals were rubber washers and not O rings.
Not saying that an O ring will not do the job. Did you not get washers with the plastic end tank?
Roger
Roger
#58
Roger,
You should be able to look at the replacement end-tank to see if the cooler ports have been redesigned for flat gaskets.
O-rings are supposed to fit in an o-ring grove to prevent crushing, while flat gaskets are compressed between flat surfaces. From the photo, the cooler appears to have a flat surface, so the 0-ring groove should be on the old end-tank.
#59
Dammit Randy why be so indvidualistic? Sheesh just tightn the bloody thing like we said ... lol I took mine to a local hose place and for 40 bux they re-did them with much better hose and brazed (braiised sp?) instead of the suaging ... suaging is for p4ssies
#60
Roger
Roger
Roger,
