Thoughts on universal vs. OEM connector 02 sensor [and Sharktuning/troubleshooting]
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Not to open another can of worms, but what are the effects of a miscalibrated MAF? I wouldn't expect that to cause different readings between the NB and the WB, but it may be another source of inaccuracy.
Can you swap MAFs with someone just to see if the running characteristics change?
I reset the LM-1 calibration using the software, turned on the LM1 to get the "heater open" message, turned it off, attached the WB02, turned on the LM1, got the warmup message, then the calibration message, then pushed the calibration button. When it was done, holding the o2 sensor, I got 20.2 AFR (or 20 point something) which is supposed to be the "right" amount of oxygen. After that, I powered down the unit and installed the wb02 sensor in the bung.
It sounds like the NBO2 sensor is responding to changes in fueling, correct? I don't know how likely it is for a NBO2 sensor to be working but out of calibration. I always thought that the calibration was a result of the zirconium or whatever it is.
What happens if you just let the LH run at idle in closed-loop mode and watch it with ST? Ignore the WBO2 number for a moment, you should see the O2-adjust number somewhere between +/- 20%, and hunting a few percent up and down as the LH teaks fuel. If you see that (irrespective of WBO2 reading) then the NBO2 sensor is behaving rationally, and the LH is able to control fueling within the adjustment range.
If it smells like gas then that's a indication that the mixture is indeed too rich. But I don't know if that is a reliable check with cats.
The fact that it goes to -128 AND the car runs worse says that autotune is going the wrong direction.
And when you add fuel manually, the idle smooths out and the NBO2 is happier. That's all telling me that the NBO2 is behaving rationally. However, fitting a new one is a relatively cheap thign to try.
(I am also skeptical that the NBO2 "breathes" through the wires, but I crimped mine just to be sure. Moisture should not be a problem if you locate the splice under the CE panel where the original disconnect is located... ).
In any event the WBO2 and NBO2 should agree at 14.7 (and ours did).
The only time I've seen the sensors not agree was recently with changing altitude, and a new free-air cal fixed that.
I changed the LM1 to the correct voltage as specified by john--0 volts at 9 AFR, 5 volts at 19AFR.
And it's plenty stinky, even with cats...
When I autotune the idle, everything goes to -128 (even using "custom" 45lb injectors rather than 42, which I'm running). When I do that, the NB gauge on my A pillar goes really lean and the car idles quite roughly. If I then lengthen the pulse width at idle, the idle smooths out some, the NB gauge starts to creep towards less lean, but the LM1 is showing somewhere in the 11s.
I would concur that somewhere I'm not getting readings that are in agreement with one another. I figured that since the WB02 sensor is new, and free air calibrates to where it should as interpreted by the LM1, that a new NBo2 sensor was the next best place to start.
are our cars twins or have a pscyhic connection or something?
Im have the same issues now.
I recently(last week) have swapped in another LH unit(and my PEMS) that cured my hot start and hesitation isues
VERY RICH at idle. Car will quit when coming to a stop at a light..etc.
-128 in idle cells. the O2 sensor shows +20% for a correction when not autotuning. Tweeking the injector sizes i CAN NOT get the correction off 20% (full scale). i dont want to change the injector size either as my WOT is based on 33.8 as a size.
Lm-1 showing one AFR...STer showing another.
i did a free a calibration after the car sat for 4 days (while at work) and it is fine....shows 20.9% O2.
i rechecked the LM-1 look up for the analog ouput...volateg vs AFR etc etc...looks good.
starts fine cold but as it warms up it starts to hunt and will eventually "choke" itself.
When i get some time to devote soley to the car im going to get the car up to temp and just unplug the 02 sensor at idle and see what happens. My Super MAF is fine, it has recently been checked by John. As a quick test, i unplugged it and the car quit right way.
Other than the idle, the car pulls like an animal now.
Good info on the O2 sensors as well, thanks. I have some more things to look into. I have mine "spliced" in as well. Perhaps this is/was the cause for my original hot start and hesitation issues...and not a bad LH?
FYI..this is on an orignal ST ver1. update to work with PEMS
Ill be picking up Ver 2 when a few other fix its get done around the house here.
I personally think it has to do with our 02 sensor(s) the way it looks..sounds..and "smells". Atleast you have cats on!
But that brings up a good point: Brian, does the LM-1 display match the wbo2 reading displayed in Sharktuner? If so, then your WB output setup is correct (0-5v = 9-19AFR).
Cheers, Jim
I thought the LM1 is what feeds the ST its data from the WB02? My point is that I would assume the ST says whatever the LM1 says, since the ST gets its feed from the aux out of the LM1.
I'll check it out to make sure. Both the ST and the LM1 have been indicating the car is running rich (which it sure smells like), but the NB gauge reads lean.
When I fatten the idle up to where the NB gauge reads "nice," the LM1 reads really rich, like in the 10s or 11s.
I did change the WB setup on the LM1 to 0 = 9, 5 = 19.
I may go ahead and run the NB emulator to the LH, so at least everything is being fed from the same 02 sensor. That takes at least one variable out of the equation.
Fuse 24 Assassin
Fuse 24 Assassin
I would try that and see what happens.
Then, get that new NBO2 sensor and do a recalibration again of the WBO2. Plug everything back in and see if there is any improvement after the new sensor.
There are three places where things can go awry:
The AFR-to-voltage conversion (which is the 9-19 range you set), a ground-reference issue with the analog voltage, and the conversion back to AFR at the ST end (which by default is also set to 9-19 AFR).
If the ST and the LM1 read the same then all those things are fine. That still doesn't tell you whether the NBO2 or WBO2 is lying, just that there isn't a third number floating around...
How is the LM1 grounded?
Cheers, Jim
Fuse 24 Assassin
Fuse 24 Assassin
I had a friend that ran dual WBO's on a Ferrari Testarossa a long time ago to troubleshoot running issues, hence my question for it at the time if that was really the right thing to do when I had installed my X-pipe. This was also the reason I did mine at the center.
Inventor
Jayzus, just buy the proper sensor, ya cheap boostards. Seriously - crimp connectors? Even if you pay the list price of $150, it's going to last the life of the car. ![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
If you shop around you should find one for around $100. Shop cost is $70 or less for a Bosch 13 048.
To the original problem, if the NB and WB are on different down pipes, perhaps there is a leaky injector, ignition, or other problem on one bank?
If you shop around you should find one for around $100. Wholesale is $70 or less.
Anyway, if you really want to do it properly, do what I do. Chop off the connector on the car side and crimp (or solder) a mustang V8 connector to the car. Then you can always plug in the $35 sensor without messing with it at all. All our cars here have '91 mustang V8 O2 connectors
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Inventor
Look at the big brain on Dan!
Except, there should be an a-dapta-kit to - plug - into the factory plug, wired to another plug, to use the el-cheapo sensor.![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
PS: only crimpers crimp on 928 parts.
Dan
'91 928GT S/C
