Part number for the pannel inside the front fender pass side, 79 OB?
This morning, I just noticed my inner fender panel is coming loose. It's the one on the pass side facing front of the car. Between the tire and the air horns inside the fender.
On closer inspection, all four of the mounting holes are gone or about to be, so looks like I need a replacement. Anyone know the proper name of this part? There is no part number that I can find on the piece itself. Also the seals that go between it and the inside of the fender are all grungy and need to be replaced too.
I think the fender piece might be part # 928.504.027.02, but can't tell from the description online. Here's a picture of it too.
Thanks!
Thanks!
Hopefully this helps you identify the pieces you require.
As well, I had a couple of mounting holes that were cracked. Some fiberglass, some time with a dremel, some black spray paint ... and the cover looked good to go. Mounted back in just fine.
Glenn
Glenn
Thank you!
