Which trans cooler lines on a '89?
Under the Lift
Malcom:
I replaced #5 several years ago and the replacement hose was about an inch too long. I could not get it to mate with the radiator and cooler fittings as there was no space to allow the extra inch of hose to bow out - the inner fender prevented this. Are you having this problem? I took the hose back to DEVEK and they found and older stock that was the correct length. This was years ago, of course. I can only get you a pic of the front of the hose. The rear is obscured by the upper radiator hose. It's the lower of the two lines in front. I would have had the old hose rebuilt but the fitting was bad.
Thx Bill.............I'm rebuilding the hose with the old fittings and new hose and clamps......it was weeping.
Believe it or not its a left over project (one of 9............I'll never attempt that many at once again) from winter '08.
The car is entered in a show at months end so I'm cleaning her up.
