Water in the alternator - how problematic is it?
Artist Formerly Known As 84totheFloor
The plastic shroud/intake hose portion of our alternators gets fastened to the electrical part of the alternator with a thin rubber gasket in between. Given what I've seen of the flimsiness of this gasket, I have to believe that water can sometimes seep into the electrical portion of the alternator.
If this happens, could their be voltage spikes? I'm still trying to put a finger on some newly-returned, but chronic voltage irregularities. They always seem more likely to happen when it's wet outside, so I'm going to call the rain in for questioning. But I'd like to know what the possible problems could be if either or both of the electrical leads in the alternator got wet.
Thanks and Peace,
Tim
P.S. There is a brown wire that offshoots from the wiring harness just before it connects to the alternator. This brown wire heads to the oil pan and is some type of gauge. This wire is in BAD shape on our car. Could that cause voltage fluctuations?
Thanks and Peace,
Tim
928 Collector
I've had that happen in heavy rain (I mean a downpour) when I had a leaky hose there, and it caused the car to lurch terribly! Intermittent power loss.
The front of the alternator where the pulley and fan is, is open for ventilation. Water is much more likely to enter there as it faces the front of the car. You'd have to assume its designed to tolerate water.
Thanks everyone!
Electron Wrangler
The shroud and hose is primarily a cooling thing - the alternator pumps air forward - so sucks from the back which is near the exhaust manifold - the shroud and hose feed relatively much cooler airt from the fender location and the snorkel hose routing is desgned to keep the intake dry and very debris free
So I'd say the shroud seal is primarily to keep the hot air out
Alan
---> Yep, that's right. Mine is very brittle and I'd like to repair it by soldering a replacement section. Soldering under the car is not a real simple task, however, so I'm wondering if I can detach that section of the wiring harness, pull it up through the engine compartment, and do the surgery from above...?
Thanks everyone![/QUOTE]
Very doubtfull, the harness that it runs through is a real PITA and would be very hard to pull the wire out of-let alone repair and the re-run through the loom. You can either repair on bottom end, or run new wire from 14 pin connecter along out side of harness down to level sensor, or if you want to do the job right, get a new harness and replace the whole thing(recomened) as if one wire is hard and brittle, so are the rest.
altenator, alternator, alternators, diy, fix, happen, heavy, intermittent, loss, mgb, power, rain, releathering, steer, water, wet
