Flywheel Bolts - install dry, with light oil or anti-seize?
The new rear main seal is in and I am installing the flywheel with new bolts.
Work shop manual does not call out installing the bolts dry, with light oil or anti-seize?
What have others done?
Thanks,
Thanks,
I just put mine in dry and torqued to spec. Just be careful that #@$@#$ triple square POS is so easy to get off-center and mess the tool and/or the bolt up, especially when working in those relatively tight quarters.
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
Former Vendor
Light oil. Be careful with Loctite. It tends to flow between the flywheel and the crankshaft, hardening there, keeping the two from touching. I never use Loctite in this application, because of this.
