Body stiffness
Hi all,
Just starting on my first TB/WP job so I jack the car up and on to 4 stands placed under the sill jacking points, go to open the drivers door to pull the bonnet (I'm English) and to my suprise the door is very diffcult to open, I have to lift the handle and really pull, I check the passenger door, not as bad. When on its wheels the doors perfectly with that reassuring clunk.
I just didn't expect that. Anyone noticed this, should the body sag? The body is rust and accident free
some cars have a tighter body than others, i do notice a difference with different 928s,,
it doesnt seem to be year specific either, some of them both doors open and close then same others have a bind and are more difficult to open when on jack stands
Thanks all,
As long as I'm not alone I feel ok, Maybe I should of added the car as 285k miles on it and a bit of old age is creaping in... bit like me :-)
My car was the same way, which worried me until i asked around and found some have this problem and some don't. I wouldn't think it so much has to do with stiffness as it does varrying build tolerances where some doors remain largly uneffected and some are effected, probably to different degrees.
Reviving a long dead post: I put my Shark up on stands two days ago and when I got something out tonight, I noticed the doors were stiff to open. Glad to hear it's not something terminal.
I guess it must be the weight of the motor and transmission pulling the ends of the car down, since the jackpoints are inboard of the suspension.
Both of the cars I've worked on did this.
This is why you should never raise the car if the strut across the engine bay is not in place. You might crack the windshield. Once it is on stands, the brace can be removed for maint.
It probably varies from car to car based on age, wear and variances in original manufacture. The door gaps and closing on my '79 don't seem to be affected when it's up on stands. The '84 S I picked up to turn into a race car seems to have a bit more chassis flex, but it has over 100k miles on it and looks to have lived a hard life.
Most folks get this backwards. Here is a recent thread on it:
https://rennlist.com/forums/928-foru...n-jacking.html
