Home Made Alternator Cooling Hose
Almost Deleted
I know there have been plenty of home made alternator cooling hose solutions posted, but hey... one more won't hurt. After replacing my fried alternator with an aftermarket Bosch unit, I figured I would try and keep it cool and make it last. The original cooling hose was toast. The fabric was not only torn, but oil soaked. I trashed it and decided to look for a suitable replacement. I didn't want to replace it with an OEM version as I don't trust the longevity of fabric on the undercarriage [especially on a car that still has a few oil leaks]. I decided to raid the local auto store just to see what sort of junk they had.
I actually found what became a great solution. Autozone stocks a generic set of parts to build "cold air" intakes for various models. They're generally marketed towards the Japanese cars. Rather than paying the money for a Greddy, you can make your own intakes with various U/L fittings, couplers and hose.
I bought two items:
I measured the output of the standard alternator cooling shroud to be 2 3/8, so the 2 1/2 reducer worked great. Everything is thick rubber, so oil+road grime shouldn't be a problem. The actual intake diameter is now larger, reducing to the standard diameter. All this for less than $30.00. I used a couple small bolts+washers to mount the hose to the stock mounting brackets. All in all, it worked out great.
Pictures:
I bought two items:
- Spectre 3" x 48" Flexible Rubber Intake Tube : $19.99: Part #8741
- Spectre 2 1/2 inch to 3 inch reducing coupler [complete with clamps]: $6.99 : Part #8751
Pictures:
Wow - another great solution!
Almost Deleted
Received 1,543 Likes
Nice find!
Used Part #8741, black, air intake cool air kit, Autozone, cut a inch out of the 2 supplied rubber ends, put them inside the supplied 3" tube, threaded the original hose clamps on (tight) and attached as original. Hopefully the plastic will last a while and not get damaged per oil etc.
Thanks for the reference !
