928 Forum 1978-1995
Sponsored by: 928 Specialists
Stranded Shark in Houston (Dean Fuller)
Old 07-15-2009, 06:51 PM
SeanR
SeanR's Avatar
Default Stranded Shark in Houston (Dean Fuller)
Dean Fuller is broke down somewhere in Houston, we are trying to diagnose why his Fuel pumps are not running and have gone through the fuses/relays/jumpering stuff and no go.
His instruments crapped out on him shortly after this occurred. Is there anyone local that can give a hand?
Old 07-15-2009, 06:54 PM
docmirror
Shameful Thread Killer
docmirror's Avatar
I hate to bring this up, but with all the fuel pumps we are going through I can only think of ethanol as being the root cause. Wish I had some way to prove it that doesn't cost billions of $$$$.
I can help by phone if he wants to call, but can't make the trip down in person.
Old 07-15-2009, 07:05 PM
Giovanni
Giovanni's Avatar
I forgot what year is his car?
Old 07-15-2009, 07:12 PM
jpitman2
jpitman2's Avatar
If current is being pulled, try reversing polarity, in case something is jammed in the pump - BTDT.
jp 83 Euro S AT 52k
Old 07-15-2009, 07:15 PM
James Bailey
James Bailey's Avatar
If it is a later car check the small + wires at the battery... if he has can get some wire run a jumper from battery direct to the fuel pump.
Old 07-15-2009, 07:44 PM
Dean_Fuller
Dean_Fuller's Avatar
My car is a 89 model...no forwarning at all. Started fine. Started in drive a couple of feet and it just shut off. No restart. After swaping the horn relay with the fuel pump relay I lost the digital reout on my dash. But will reset with battery disconnect reconnect...dash lights for about 5 sec then nothing. Jump fuel pump...nothing. No injector noise or fuel pump noice or smell of fuel. Will check current wen I buy a volt meter. I know someone local but hes not a car guy thats helping me.
Could this be the LH?
Real bad day...we just found out my sons cancer is back and then this on the way home.
Old 07-15-2009, 07:46 PM
Dean_Fuller
I will try that Jim...thanks.
Old 07-15-2009, 10:09 PM
Sailmed
Sailmed's Avatar
Location: In the boatyard installing the mast and engine, we don't need a crane, we harness the mesquito's! Yeah!
I have no idea about the car my friend.... I wish I had the answer
but all the best wishes for your son.... I wish I had the answer for this, even more.
Old 07-15-2009, 10:18 PM
scottzj
scottzj's Avatar
I was told there is a call listing for members that have said they would help others if they were in their location. I know this is somewhat off topic, I would like to be addd to this, as I am always willing to help out others in need.
Old 07-15-2009, 10:22 PM
IrishLegend
IrishLegend's Avatar
Dean, My 4 year old son just got over (fingers crossed) stage 4 neuroblastoma cancer so I know what your going through. Your son and your family will be in our prayers.
Old 07-15-2009, 10:29 PM
robot808
robot808's Avatar
Jesus Dean, Really sorry to hear about your son. The fuel pump is a real nice kick in the teeth. I like Jim's idea of wire right to the pump.
Old 07-15-2009, 10:41 PM
Giovanni
Giovanni's Avatar
Dean, sorry to hear about your son man. Have you tried to start the car ones it cooled down? I know when the brain on my 84 died, the fuel pump would turn on when bypassed but would not work otherwise. So when you bypass your it does not do anything? I hope its something small and not the LH. I have a used external fuel pump if you need it. Www.azautohaus.com IIRC had the best deal on internal fuel pump.
Old 07-15-2009, 11:30 PM
cold_beer839
cold_beer839's Avatar
Dean, he beat it before, he will beat it again.
Anybody have an LH cpu to swap in there?
Old 07-15-2009, 11:35 PM
BBX
BBX's Avatar
There is a fuse that control the digital part of the dash, i know, i just found it on mike's car last week. i think it says controls on it? i dont have a copy of the fuse chart in front of me so i cant remember which on was. i happened upon it when i was wire brushing all the fuses and relay contacts
Old 07-16-2009, 04:31 AM
Nicole
Cottage Industry Sponsor
Nicole's Avatar
I'm so sorry to hear about your son, and cross my fingers that he will be cured.
I also hope you can get some local help for your car troubles.
This is the 928 Road Help List. I don't remember who maintains it, and it doesn't say who on the list. My list is from May 2006.
There are a few people listed in Texas, but I don't know which are close to Houston. Most seem to be around the Austin or Dallas areas.
Quick Reply: Stranded Shark in Houston (Dean Fuller)
