Grease splatter on inner rear pass. wheel
Was checking a massive trans oil leak by resevoir and noticed alot of black grease splatter on the rear passenger inner wheel ,it was definetly fresh grease would this be a boot or something.
Im at the stage now, like so many others, that the car will just sit now,because of the frustration,this is what happens with these cars,it will sit there then in like 3 years ill sell it,and that person will get frustrated then it will end up as a parts car,its an ongoing cycle.
Nope its ok guys I know what the problem is.
What you are seeing happens MOMENTS before the car is about ready to catch fire.
I recommend that you immediately sell the car VERY cheap, because you now know this you cannot sell if for full value. Once you sell it move on and NEVER buy another one!
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Actually it is CRAZY to think that a 20 year old car is not going to have problems need work just like people , cars wear out ....rubber falls apart, the plastic cracks, leather gets hard , it is just life. Sell the car now and move on little point in parking it and watching it disintegrate.
After looking at dwaynes cv write up,this is something i cant do,i dont want to get that grease all over my hands im getting a manacure today ahahhahhahhahhaha what parts on the trans reservoire leaks like this?
Team Owner
the trans could have an over tightened pan gasket and after a while it cracks and lets the fluid leak out.
The tank cap could also be loose.
The front pump seal/TC seal could be leaking ( verified by seeing fluid dripping out of the grate on the bottom of the TC housing)
The hoses that go to the trans could also be leaking, if these are leaking then the ones that go over the cats should also be replaced
if you think you have replaced 50% of the parts, you really have no idea.
Just wait till you have to try to track down a wiring glitch!!!!!
And yes JB sometimes it is better to let it burn............
with the owner trapped inside the unable to break his way out cause he spent his money on a pedicure instead of an ipod and didnt want to chip a nail!!!!!!
Rest in Peace
I think he needs to go look at new cars, and while he is at the dealership, maybe go look and see how many new cars are in the shop.
