Before & After Picture Thread
Inspired by 6mil928's before and after thread (looks great!), post two pics of your car. First pic from when you first got it, and what it looks like today.
Arrival day 11/26/2007, the day after my birthday! My son took this picture on a rainy afternoon, but I didn't care.![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
![](http://i208.photobucket.com/albums/bb49/mlitherland/928/100_1982.jpg)
Crappy cell phone pic from 10 minutes ago.
![](http://i208.photobucket.com/albums/bb49/mlitherland/928/IMG_0157.jpg)
Where to begin, I bought a car with 20+ years of consistent records including a lot of big $$$ items. Then I got started. New brake rotors, rebuilt calipers, brake lines, clutch master/slave/lines & lever ball cup, shift bushings, coupler and Carl's front cup, a/c expansion valve & fresh R12 (ice cold!), all exterior lights/bulbs including 7" E-code Cibie H4s, new water pump and PKns'r, new power steering lines, cam tower gaskets, smog pump delete and Motorsports Y-pipe, Fikse 17" FM/10s (courtesy of Sterling), new battery yesterday, and Borla SS secondary and primary mufflers going on next weekend...and I'm sure I'm forgetting stuff. Wow.
Not the sharpest tool in the shed
Very nice. Would be good to hear what sort of things you have done to the car during your ownership.
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Shortly after I got my eBay gem I got to fixing some paint issues (when I found out my white car was originally Cassis Red Metallic)... anyway, I liked it white. Now, it is custom White Pearl. Before & after:
Team Owner
Ebay special, rescued from the the hands of time and wear and tear
I've had my car some time now, but here's the biggest "milestoneS"
![](http://www.nospoons.com/Porsche/busted-ride.JPG)
![](http://www.nospoons.com/Porsche/928-rear-sus.JPG)
5/30/09
Didn't make SITM, but was damn close. Who knew this car needed so much repair when I bought it?
![](http://www.nospoons.com/Porsche/tight-timeline.JPG)
Today!
6/20/09
![](http://www.nospoons.com/Porsche/928-done.JPG)
![](http://www.nospoons.com/Porsche/928-1.JPG)
the list! I have the pirces logged but I don't want to scare anyone.
date item
10/20/2003 1987 928 S4
11/1/2003 porsche swaybar mounts
4/21/2004 2 front tires -- 225/45WR17*Yokohama*AVS ES100*
4/21/2004 tire mounting
5/1/2004 SS RMB
5/1/2004 3 oil filters
5/1/2004 2 trunk shocks
5/1/2004 3 crush washers
5/18/2004 wet sand
5/18/2004 2 hood shocks
5/28/2004 cable
5/28/2004 cable & spare relays
5/24/2004 Oil and transaxel fluid
8/22/2004 tire mount & balance
8/22/2004 2 rear tires 255/40WR 17 AVS ES 100
9/7/2004 911 731 33 Sun Visor Clip**(2)
9/7/2004 928 555 60 **** Armrest Box***********
9/7/2004 928 522 41 Rear Seat Belt Rose******(2)
9/7/2004 928 602 21 Ignition Rotor 85-95******(2)
9/7/2004 433 867 29 Door Panel Clip - White******(2)
9/7/2004 928 606 14 Fan Temp Switch 87-95*********
3/12/2005 wheel smash
3/12/2005 2 front tires -- 225/45WR17*Yokohama*AVS ES100*
4/14/2005 Mount & Balance
4/14/2005 Alignment
4/17/2005 8 new Bosch park plugs, 10 qts MOBILE 1 15W50
4/17/2005 New plug boot
4/17/2005 New front wheel
6/6/2005 928 Specialists F&R swaybars and adj. Links
7/15/2005 New relays
8/12/2005 New drivers window seals, sunroof seal
8/15/2005 Koni Hypercoil kit
8/15/2005 Aluminum undertray
8/15/2005 Short Shift kit
9/11/2005 New Battery
9/18/2005 ground cable
9/18/2005 new rear wheel
11/10/2005 New headlight bulbs
2/1/2006 Maintenance Covers
2/1/2006 Al steering rack mounts
2/1/2006 New exhaust gaskets
2/1/2006 New O2 sensor
3/8/2006 Oil change
3/8/2006 2 rear tires 255/40WR 17 AVS ES 100
9/1/2006 Bridgestones
12/18/2006 *Timing Belt 83-95 Continental
12/18/2006 *Tool 9131 - Timing Belt Tensioner Tool
12/18/2006 *Timing Belt Tensioner Arm Bushing 85-95
12/18/2006 *Timing Belt Tensioner Inner Piston Seal 83-95
12/18/2006 *Timing Belt Tensioner Gasket 83-95 Genuine Porsche
12/18/2006 *Timing Belt Tensioner Boot 85-95
12/18/2006 *Fuel Filter 80-95 US
12/18/2006 *Tool 9235A - Relay Remover - OTC
12/31/2006 used central warning control module
1/4/2007 00072191612 Universal Flywheel lock
1/4/2007 90012304220 Crush Ring 14X18 for steering
1/4/2007 92810644401 Radiator Drain Plug 78-95
1/4/2007 92834744505 Pwr Steering Supply Hose 85-95
1/4/2007 92834744907 Pwr Steering Return Hose 87-90
1/4/2007 99919226650 Alternator Belt 85-90,
1/4/2007 U92810704101 USED Oil Dipstick 86-95
1/15/2007 90012300730 Crush Ring Dip Stick 14X18 1.00
1/15/2007 90024900802 Countersink Screw on Late WP 2.00
1/15/2007 92810551212 Tension Roller 78-95 1.00
1/15/2007 92810557104 Idler Roller 87-95 1.00
1/15/2007 92860621303 Oil Level Sender Gasket 1.00
1/15/2007 92861286700 Positive Connector block 1.00
1/15/2007 92861287102 Positive Terminal Shield 1.00
1/27/2007 New vacuum lines
1/20/2007 Wiring connector
1/27/2007 Timing tools
3/17/2007 Mount & Balance REAR bridgestones
7/1/2008 New C&R rad
7/1/2008 New Fans (2008 maserati)
9/1/2008 PorkTensioner brackets
7/15/2008 Tensioner
7/15/2008 Lever
7/15/2008 Pulley - Ruville or Ina
7/15/2008 Tensioner Gasket
7/15/2008 Water Pump
7/15/2008 Tensioner Bolt M8 x 55
7/15/2008 Timing Belt 83 to 95
12/10/2008 center console
12/2/2008 valve cover gaskets, etc
12/16/2008 Luggage Cover - Black
12/16/2008 Universal O2 Sensor
12/16/2008 Silicone Oil Pan gasket
12/16/2008 SS Stud Kit
12/16/2008 Ford Injector O Rings
12/16/2008 New Flappy Bearings
12/16/2008 Knock Sensors
1/8/2009 Analog clock
12/10/2009 92810553001 (used cam sprockets, x2)
2/6/2009 32 Valve Stem Seals 32V - 928 104 601 07
2/6/2009 Hall Sensor 944 606 170 01
3/9/2009 head machine work
3/17/2009 *Ball Joint Upper/Lower Boot 77-95 431.407.377.A x2
3/17/2009 *Camshaft Seal - "ARM"(updated) 85-95(32v) *928.105.205.00 x6
3/17/2009 *Camshaft Seal - End Seal (updated) 85-95(32v) *928.105.215.00 x6
3/17/2009 *Cylinder Head Gasket Cyl 1-4 85-95 *928.104.367.05 x1
3/17/2009 *Cylinder Head Gasket Cyl 5-8 85-95 *928.104.368.05 x1
3/17/2009 *Camshaft Seal - "Driven" - 77-95 *999.113.282.40 x2
3/17/2009 *Exhaust Manifold Sealing Ring - 85-95 32V *944.111.205.00 x8
3/17/2009 *RUBBER O-RING *90017405640 x6 (used in valve covers)
3/17/2009 *Oil Pan Drain Plug SEAL *900.123.118.30 x5
3/17/2009 *GTS Oil Pan Baffle Kit *928.107.139.07.KT x1
3/17/2009 *Camshaft Chain Tensioner Pad Repair Kit 87-95 *944.105.949.00 x2
3/17/2009 *Coolant Crossover O-RING All *999.701.627.40 x1
3/17/2009 *Coolant Crossover Gasket 85-95 *928.106.227.00 x1
3/17/2009 *Clutch Arm Ball Cup Bushing *928.116.145.03 x1
3/17/2009 *Intake Removal/Refresh Kit for 87-95: *928SP.KIT.INT. x1
3/17/2009 **-*(1)*928.107.313.02 - 87-92,
3/17/2009 **-*(1)*928.107.445.02,
3/17/2009 **-*(1)*928.110.174.09,
3/17/2009 **-*(1)*928.110.224.00,
3/17/2009 **-*(1)*928.110.580.02x2,
3/17/2009 **-*(1)*928.110.633.00,
3/17/2009 **-*(1)*928.110.637.04x2,
3/17/2009 **-*(1)*928.110.663.00,
3/17/2009 **-*(1)*928.110.694.01x10,
3/17/2009 **-*(1)*928.110.713.01/928.110.714.01,
3/17/2009 **-*(1)*928.574.717.02x10,
3/17/2009 **-*(1)*N.020.139.1x2,
3/17/2009 *Engine Block Coolant Drain Plug Seal 77-95 *900.123.055.30 x2
3/17/2009 *SCKT SCREW 8X53 *90006728402 x10
3/17/2009 900 123 050 30 - Crush washers for tensioner oil lines (10)
3/28/2009 Blue Oval industries 24lb injectors (new) x8
4/7/2009 Updated clutch arm 928.116.832.09
4/7/2009 Updated guide tube 928.116.087.16
4/7/2009 GTS clutch
4/7/2009 T/O Bearing
4/7/2009 rad tank
4/7/2009 vaccum check valve
4/7/2009 gaskets
4/7/2009 oil check valve o-rings (in head)
4/7/2009 Windshielf washer tank neck
4/7/2009 Heater valve
4/7/2009 clutch hose
5/1/2009 intake spacer
6/3/2009 powdercoat
6/3/2009 flappy valve and massive shipping
6/3/2009 New cam seal and belt
4/7/2009 solid MM
5/30/09
Today!
6/20/09
date item
5/1/2004 SS RMB
5/18/2004 wet sand
5/28/2004 cable
4/14/2005 Alignment
3/8/2006 Oil change
7/15/2008 Tensioner
7/15/2008 Lever
4/7/2009 GTS clutch
4/7/2009 rad tank
4/7/2009 gaskets
6/3/2009 powdercoat
4/7/2009 solid MM
date item
5/1/2004 SS RMB
5/18/2004 wet sand
5/28/2004 cable
4/14/2005 Alignment
3/8/2006 Oil change
7/15/2008 Tensioner
7/15/2008 Lever
4/7/2009 GTS clutch
4/7/2009 rad tank
4/7/2009 gaskets
6/3/2009 powdercoat
4/7/2009 solid MM
date item
5/1/2004 SS RMB
5/18/2004 wet sand
5/28/2004 cable
4/14/2005 Alignment
3/8/2006 Oil change
7/15/2008 Tensioner
7/15/2008 Lever
4/7/2009 GTS clutch
4/7/2009 rad tank
4/7/2009 gaskets
6/3/2009 powdercoat
4/7/2009 solid MM
eerg!!! that's still an ouch, man! Fire = Bad.
My wife actually caught sight of the 928 "update" list
(with the cost and price total). Good thing she get's a regular supply of nice furniture.
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
My wife caught mine too, and pointed out a few things I missed...ouch. Barry I had no idea your car had been through that kind of transformation, looks fantastic. And Joey, we'll expect to see a much better before & after with your new car.
