View Poll Results: What to do about broken exhaust bolt?
Drill it on the car with manifold in place.
7
43.75%
Only drill it with the head off the car.
6
37.50%
Leave it alone and embarass the 928 crowd at the OCIC
3
18.75%
Voters: 16. You may not vote on this poll
Simple Poll About Broken exhaust Bolt
#31
Team Owner
there should be 2 manifold supports that are connected to the 2 lower bell housing bolts one on each side if you dont have these then they need to be fitted B4 your finished
#33
pull the engine, then use an impact gun (after using kroil for a few days) to undo all the nuts and studs.
Hope that they come out of the head and not the nut backing off.
Once the manifold is removed use a MIG welder and weld a nut to the head and let it cool on its own. Do not accelerate the cooling process. If the nut isnt flush with the head you can give it a smack or two to help free it too. Then again use the impact gun to remove.
Once they are all out use a thread CHASE to clean the head. Replace all studs and nuts with new. Use liberal amounts of never-sieze (silver colour) on the studs. (coat the entire stud)
#34
Location: No where Oklahoma AKA "The Dust Bowl" In The Arm pit Of Hell
#35
I can't believe that no one has a picture of their exhaust they could post. Must be Friday night and everyones out drinking.
#37
#38
Jason, I looked all over and couldn't find any brackets yesterday. Sorry my friend.
#39
Sean thanks I know you tried hard. I looked all over with search and can't find a picture of these brackets. I guess I'll check the PET and see if they're there if not I'll be fabing something and it might not be pretty.
#40
I've got to get my car up in the air to fix the spoiler (tore it off at SITM) so I'll take pics of mine.
#41
Ok guys here's the conclusion. Got the new manifold installed and exhaust back together tonight. Car sounds excellent what a difference. I no longer think it's too loud it's now perfect.
#42
Team Owner
did you fit ne manifold supports? If not your work is on borrowed time.
Goodluck on you project
#44
