928 Forum 1978-1995
Sponsored by: 928 Specialists
Big Brake Conversion Issues HELP!!!!
Old Aug 14, 2011 | 11:16 AM
  #46
heinrich's Avatar
heinrich
928 Collector
Originally Posted by Fabio421##
Good morning heinrich. What brand are the rotors and what are their part numbers?
Good morning Shawn they're Porsche parts in the box. I'll check for you.
Old Aug 14, 2011 | 11:50 AM
  #47
mark kibort's Avatar
mark kibort
really?? are they 993T or 993TT? if they are 993T (965T) ill take them if they are price slashed!
Originally Posted by heinrich
I have 2 sets of drilled big rotors I'll sell at a decent discount.
Old Aug 14, 2011 | 12:21 PM
  #48
heinrich's Avatar
heinrich
928 Collector
https://www.928gt.com/ps-1841-130-bi...ece-rotor.aspx
There won't be any price slashing here Mark, but yes they are 993TT - the drilled 2-piece ones that fit the earlier 928's with Big Reds.
Mark, I'll make you a deal ... get my cams made and all 4 these are yours.
Old Aug 14, 2011 | 12:30 PM
  #49
mark kibort
ha ha! actually, i cant use the 993TT rotors. this thread has been going on for some time. forgot what was talked about here. i use the 964T rotors, (965) which are just the same as GTS rotors. 322mm, but a totally different offset than the 993 rotors.
guess I lll continue to use, used GTS flat rotors as i find them all grooved up!
Old Aug 15, 2011 | 04:18 AM
  #50
Andy928S's Avatar
Andy928S
Andy, even if they hadn't touched the rotor you should change out the aluminum ball joints. It's a potential failure point and they were recalled by Porsche if I remember correctly.
The very next thing to do, yes.
They are only there as they came off my '79 and were difficult to remove, now the 79 has the new steel ones.
Will also be replacing the dust guards, which should disperse some heat/ keep heat off the balljoint rubbers.
