Big Brake Conversion Issues HELP!!!!
Man of many SIGs
if you are using S4 calipers, you cant use the 322mm rotors as they will hit the rotor BAD. you need to dremel off about 2mm of material at the edges. when they bolt on they will wedge the rotor to the caliper. Iguess if you drove it for a while it might grind itself down, but that would be pretty ugly.
mk
mk
The S4 rotors are what I need. I have already tried it and it works. I think I can fabricate an adapter to be able to use these rotors with my s4 calipers but the pads don't cover the whole disk. Far from it. So I think the only advantage there would be the increased leverage from the larger diameter. I don't know if its worth machining new adapters for that.
mk
mk
I checked them, I did not grind anything off of the calipers. I am using calipers off of an 88 S4 and a set of rotors that I bought from Roger.
Fabio,
I am not sure the rotors are the exact same one you have. Is there a parts number somewhere on yours? I may be able to remove the wheel tonight and check for a parts number if it will help, but I am getting on a plane for Mexico at 6am tomorrow.
Shawn thanks for the thread
... now I am interested in what adapter you can make to fit your S4 calipers to the 993tt rotors, as this is what I would have to do to use my 2 sets
Man of many SIGs
Mark,
Fabio,
Fabio,
I think I can make an adapter to fit the S4 calipers to the 993tt rotors on an OB spindle, not an S4 spindle. The adapters you need are just spacers I think. Isn't that what Mark Kibort is doing?
I have 993TT rotors on my 87 s4 5spd I drilled some 3/8" X 1" aluminium flat bar to match the bolt pattern on the caliper and spindle for spacers. Then had to die grind the inner edges of the caliper to clear the larger rotors as per MK's thread. Took about an hour to make the spacers and grind the calipers to fit. You will need longer caliper bolts to compensate for the added thickness of the spacers.
I bought mine from Porsche but you can probably get them elsewhere much cheaper.
Great cheap up grade. Makes for better pedal feel under hard breaking.
Only problem is the rotors cracked all to hell after three track days, I would try and get slotted rotors if you track the car.Other wise I'm sure the drilled rotors will be fine for street use.
Man of many SIGs
How did you address the radius issue with the larger diameter rotors ?(322mm, which is the same as GTS or 965 rotors like I use ). the S4 caliper can not fit the larger rotor, due to its smaller radius accomidation design. (unless you dont mind the pad hanging over the edge of the rotor, and the adapters positon the caliper this way)
the adapters you have made are different from the ones generally made from the custom shops, as it allows for the use of the 993TT rotors, right? (just a different offset)
mk
mk
Man of many SIGs
mk
mk
The calipers fit the rotor well and without modification. There is only one small part of the pad that isn't contacting the rotor and it is at the top center "point" of the pad. It is only hanging over by 1mm and it is a pad area that is only a few mm wide. Not enought to worry about and certainly not worth grinding on the caliper in my opinion.
To answer your second question. They are similar in design and material but different dimensions. They will not work on an S4. They will only work with the early spindles.
its 2mm at the top, but i understand, you dont care if you have a little pad hanging over and wear that pad kind of funky as it leaves some material on the edge as it wears. I made my spacers to have the top of the pad meet the top of the rotor. the edge of the pad will be below the edge of the rotor by about 1-2mm, which is fine. these pads are the same exact pads that are used on the Stoptech ST40s which use the S4 as well, and are 13" rotors, so its a professional way to solve the problem.
Grinding the calipers by 1-2mm on the edges is an easy fix with an air tool, and a little longer with dremmel but really easy.
can you post the pics of the adapters?
I want to see if there is a way to get that hat on 993 rotor to work on the 84s, so that the offset can be an advantage for a .25" piece of steel that can be threaded for the side mounting caliper bolts and through holes to the hub with bolts. basically, moving it inward
mk
mk
Mark,
When the rotors screws were tightened down, the rotor contacted the lower ball joint.
And this is what it looks like, 993 rotors, s4 calipers adapted to fit larger radius contacting ball joints.
New steel ball joints on the way!
Andy '83 S & 79
Man of many SIGs
Good morning heinrich. What brand are the rotors and what are their part numbers?
I have to say I don't like this mod, even if it didn't hit or touch it is way too close to the disc, imagine when the disc gets very hot and then you stop the car. Think about the heat soak and what about the rubber boot with all that heat?
