928 Forum 1978-1995
Sponsored by: 928 Specialists
WBO2 noob - how many inputs do I want?
Old 06-15-2009, 08:40 PM
jcorenman
jcorenman's Avatar
Originally Posted by Xlot
My understanding was that the EZK load signal is available for logging - pin 25 on the 35-pin LH connector? That coupled with rpm and AFR should be enough to calculate map changes?
Not for the LH. The base fuel-map is RPM vs. load, but it is not the same load signal that the LH sends to the EZK. The LH map uses an internal load calculation which is not accessible externally.
Cheers, Jim
Old 06-18-2009, 12:13 AM
Hilton
Hilton's Avatar
Thanks all for the input - I pulled the trigger on a 3A2 yesterday afternoon and it arrived this morning, along with an LA-1 gauge.
I'll post how I get on when I get time to plumb it in and play with it (focus is on the '87 until that's road registered).
Hilton.
Quick Reply: WBO2 noob - how many inputs do I want?
