Rapid ticking sound from engine bay
I am not very savvy with the mechanics of any car so please forgive me if this post sounds ignorant.
We recently took our 928 out of winter storage. I notice that the car is running a bit loud and 'rougher' than normal. I figured this might just be because it hasn't had a tune up yet. But what concerns me is that there is a rapid ticking noise coming from the engine bay. My worst fear is that there is a cylinder that is not firing or anything.
Any of you 928 lads know what is wrong with my car?
It could just be your fuel injectors. They make an audible ticking. Another possibility is a sticky lifter, which can happen if a car sits for a while. Drive it a while and the lifter should get oiled and quiet down. if they stick, they make a louder, clacking sound.
The injectors firing is a more rapid ticking sound than the lifter.
Matt
Matt
Team Owner
of course it would help if you had the info about your car in the profile.....Not all 928s have clicking injectors
.What year is your car???
Put your fingers on the fuel pressure damper at the front of the engine. If you can "feel" the clicks and they match what you hear, then it's the fuel injectors. It's a normal sound.
Team Owner
1986.5 has the clicking injectors
After I put my SC on the injector ticking became much louder and scared me. If you have a stephascope ( you know, the doctor thingy) it will tell you right away. If you don't have one they are very cheap and a good tool. Habor Freight is a good sorce.
Good luck
Good luck
Craic Head
Agree, there is ticking, clicking and clacking from the top end.
I would guess the ticking is an injector sound. It won't go away when it's warm. This is normal and goes away when you shut the hood
Clicking: Dry lifter noise that generally goes away when warm. The more you drive your car, the more your car will like you and won't make these noises as much.
Clacking: stuck lifter that doesn't go away when warm.
For the lifter issues I'd try some Rislone in your oil. Run it in your engine for a little while with your oil (a few weeks or several hundred miles of steady driving), then drain it out and put in new oil and filter. It worked for me.
Matt
Supercharged
At SITM we (Bobby Huff and I) helped a gent who had an 85/86 car also with a ticking noise at idle. Sounded like something from the passenger cam. After figuing out that it was only at idle, we determnined it was the ISV (Idle Stabalizer Valve) that was making the noise. Just another thing to put on your list; however, it's not something that needs to be replaced. The gent we helped said it had been like that for the past several years.
