928 Forum 1978-1995
Sponsored by: 928 Specialists
4.5 to 5.0
Old 06-05-2009, 03:29 AM
mark kibort
mark kibort's Avatar
You could do 968 pistons and get a near 5.4 liter. (with a stock S4 crank and that would be a cool set up) But, after all that work, you might as well put a stroker crank in there with rods to match and get the 6.4 liters.
Originally Posted by LightStriker
Isn't the GTS a 5.4L? Wouldn't it be possible to do a 5.4L hybrid?
Didn't I read stuff about 6.0-6.5L using 968 pistons or something like that?
Old 06-05-2009, 03:50 AM
Lance J
Lance J's Avatar
what is his setup euro top end????
"My friend Ron has a 78 5.0
GO'S LIKE HELL"
Old 06-05-2009, 08:05 AM
LightStriker
LightStriker's Avatar
How a stroker crank/rod give almost 1 more L over S4 crank? Longer displacement?
Old 06-05-2009, 09:19 AM
toofast928
toofast928's Avatar
The hybrid set up goes like this:
  • 5.0 short block
  • prefer euro heads but not necessary if USA heads are ported
  • Must have Euro TB and intake runners
  • 32v SS exhaust manifolds, dual or 3" single exhaust
  • Can keep L-Jet or CIS
For N/A engine this combo yields 280-300 HP and lots of torque. DIY cost around $1500 to 2K
Add a S/C and pick a horsepower range 400-500.
I'm oversimplifying the process but in an OB 5.0L is the logical choice to more HP. 32v conversions have been done but be prepared for more $$/time/and headache.
-Tony
Old 06-05-2009, 11:03 AM
mark kibort
stroker crank goes from 78.9 stroke to 90mm+ stroke (I forgot exact number)
bore goes only from 100mm to 103.7mm
mk
Quick Reply: 4.5 to 5.0
