Hall Sensor Wiring Routing
The new hall sensor wiring is shorter than OEM and was curious how folks who have replaced the sensor have routed the cable.
The OEM wiring leaves the bottom of the sensor and then heads straight up so that attaches to its mating connector from above.
I'm thinking the sensor connector could route from below..........any issues?
(i thought I read previous that JDS was concerned about specific cable routes for the hall)
I had this same problem....the part #'s are slightly different too....what Bill & I did on sharky is not use the mounting holder piece and just zip tied it into position on the side of the bracket...that is the only way it would work without a SERIOUS bend in the wire....
https://rennlist.com/forums/928-foru...ht=hall+sender
Received 1,318 Likes
There is a nice picture in Rob Edwards thread here...
https://rennlist.com/forums/928-foru...s-missing.html
Hope this will help.
Under the Lift
Rob's way only works because he has misrouted the harness wire. It's infront of the cam belt cover. It should be behind the cam backing plate. If you can still get the cam belt cover off, no problem. As Brian says, we just didn't try to mount it in the bracket. I don't understand why they changed the Hall sender and why it costs as much as $250 from our 928 vendors.
The bracket you zip tied to was the engine hoist bracket?
Received 1,643 Likes
Here's my post from that other thread:
If you loosen the Phillips screw on the cable clamp for the new (shorter-cabled) Hall sensors you can extend the connection cable by the few millimeters necessary to orient the connection in the factory position. Then position the connector in the bracket and wind the Hall sensor into place in the cover and install the assembly on the motor.
Not sure where you source parts (assume locally) but the vendor I bought from was slightly above $100.
For those following along here a pic; OEM is on the left, new is the right with cover temp. installed and the connector inverted:
ok............I tried Daves method of loosening the screw to gain a few mm of cable but I still dont feel comfortable stretching the cable.
Back to square one............is there an electrical/signal issue mounting the connectors inverted?
I can mount the new sensor connector to the holder as well as the spring keeper in the inverted position.
