Easy (?) quiz: What's missing?
Archive Gatekeeper
I discovered a new part I didn't know I was missing from the GT when I took apart the GTS. Never seen one of these before, though I'm sure they're common. Tell me what's missing and I'll post a pic of it tonight.
Roger- got a part number? I need 4.
![](https://webfiles.uci.edu/redwards/public/1-4%20bank%20engine%20hoist%20wire%20routing%205-24-09.jpg)
![](https://webfiles.uci.edu/redwards/public/1-4%20bank%20engine%20hoist%20wire%20routing%20%232%205-24-09.jpg)
Archive Gatekeeper
I'm stuck 'cause I can't convince my 8 year old to hold the clutch master in place while I bolt it in, so the engine is just sitting and I keep detailing it. I may have to bust out the 5 year old to get this done.
Under the Lift
Actually I was going to say the same as Jim, and the harness usually runs behind the cam gear backing plate, but to do so, I think the connector must be flipped. Also, I have found with the currently available Hall sender, the cable is too short and the clip does not fit anyway.
Archive Gatekeeper
Jim-
AFAIK, I think there's only 2 per engine- one on the Hall, one on the front knock sensor.
Here's the culprit (off to be replated Tuesday):
![](https://webfiles.uci.edu/redwards/public/Hall%20sensor-%20knock%20sensor%20retiner%20clip%205-24-09.jpg)
Basic Sponsor
928 606 282 00
Only shows one on the hall sensor - no where else.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Chronic Tool Dropper
I need to take a slew of pictures, inch by inch, of that motor while it's out on the stand. That way, when I later need to find the right cuss word for getting that little upper %&$#!! bolt out for the Hall sensor, I'll know which one to use.
The new plating on all these parts makes them look better than new. Roger-- How much is a new one of those clips? Might be cheaper to buy it, have it shipped new vs hauling the old one to the plater. If the new one comes plated like the rest of these 'new' parts.
I've got several of those clips. When you replace the hall sensor the clip no longer fits on the cable. The factory and replacements are different diameters where the clip goes, so it just kinda hangs there.
Rest in Peace
What plating are you using? I assume it is electroless nickle with yellow chromate? What is the plater doing about stripping the old plate?
