Rob's GTS engine pull
#121
Archive Gatekeeper
Greg did some post-mortem (and I do mean post-mortem, now...) measurements on the crank today:
And I quote:
Quote:
Worn .040" on backside of throw. Will need to go to .060" to clean, maybe .080. Can't chrome a journal that far.
Crank is bent .008"
Would need to be welded, straightened, machined, and the mains will need to be .010 undersize to fix the "bend". Might crack when welded. When done, you will have a "used carlot" repaired crank.
And I quote:
Crank is bent .008"
I stopped by Greg's briefly on Friday, and he handed me a crankshaft in a plastic bag. I didn't recognize it and was confused for a minute till I realized that he'd sent out my dead crankshaft, and had it straightened, welded up, and had all the shrapnel damage cleaned up. All main and rod journals are within 'new' spec for a GTS crank. Looks pretty good for a used car lot crank....
Old n' busted:
2-6 journal:
The 'new' hotness:
thrust surface and 2/6 journal:
Closeups on the welded-up 2/6 journal:
And another.
#124
Archive Gatekeeper
Mike, I'm going to sit on it until we (and by 'we' I mean 'Greg') figure out what it's gonna take to fix this:
#126
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
thinking out loud, my short list of very good~great Porsche engines; 968, most 911s w/ turbos, Carrera GT, Cayenne, and (too soon to tell but probably) Panamera...
when good bearings go bad...
http://www.enginebuildermag.com/Arti...gs_go_bad.aspx
#128
Archive Gatekeeper
There were no rod bearings left at all on the #2 journal, so I'm not sure what went wrong....
#131
Archive Gatekeeper
No, but it's heavier now than when I gave it to Greg.
runs off to the garage to get the scale.....
#132
Captain Obvious
Super User
Super User
#134
Not the sharpest tool in the shed
The GTS has a built stroker in it. This is the original engine that cratered on the drive home after picking it up in Oregon.
