I think the differnce in 3rd vs 5th breaking is that 5th is the input shaft to the torque tube at breaks at that coupling point, and 3rd is the actual gear that fails by stripping or breaking off teeth.
I hope he can get this thing together in time!
Mk
Originally Posted by svp928
Mark, send me a sample and I will see about making replacements...doesn't 3rd fail also?
I dont think it is the gear that broke, its usually the shaft that fits to the torque tube. What would drilling a hole and welding it up do?? Is that if the gear itself was failing? Just curious.
mk
Originally Posted by Lizard931
Are you able to have anything done to the gear which may prevent it from grenading? Say drilling a hole and having it filled by a TIG welder?
For starters the Porsche clubs require you use a Porsche gearbox but when they break they are not totally lost. For a while Porsche was selling new GTS 5th gears for under $500. No longer the case
There are 911s and 944s with aftermarket sequential gearboxes in PCA GT classes...
