Installed Autothority chips today - wow!
Captain Obvious
Super User
Super User
I shaved 2 tenths off the 1/4 mile with nothing more than a chip set, on a 100% stock car. Went from a 13.7sec to a 13.5sec for $40!
So not to hijack the thread or anything. But if I purchase a chip set for my S4 and the x-pipes how much power would I be making. Car is all stock otherwise.
The chips claim 30hp gain and the x-pipes claim 20. The car is 320 horse stock, so that means I would have maybe 350-360 hp when both are installed? Any experience would be appreciated.
Craic Head
From what I've read, the S4s don't gain as much from just a set of chips because the timing and fueling is already pretty well set up. The reason the S3s can pick up so much is that they were the first 32v cars and the factory tuning was very conservative. As mentioned earlier in this thread, there are no knock sensors in the '85-'86 so you take a chance if you run more aggressive tuning, especially with lower octane gas.
I always run premium and I fill up at chevrons and shells only. I added a chip to my old 944S and I easily gained 15 ft lbs of torque. Autothority usually does a good job of holding true to their claimed gains. Im also aware that throwing parts on a car is not a cumulative process. I am just trying to decide the best way to mod my car with my limited budget.
Chronic Tool Dropper
In the wayback era, we added AA chips to Phil Tong's GT, and gained maybe 10HP. This was back-to-back dynojet runs. His car had RMB but x-pipes weren't available yet. That was 8 years ago, no telling if the programming from AA has improved since then.
I added the same set to my '89 S4 and had noticeable results. It felt quicker. Hot ambients, low RPM's, AC running, and a firm push made audible pings so I pulled them. They are in the parts storage bin someplace. I need to do an intake clean and refresh, de-carbon, new plugs and wires. Then try them again. I drive the car like a white-haired senior citizen anyway, so I'm not sure if there would be a benefit for me anyway. You young whippersnappers would likely enjoy the extra push.
Hatch--
Get the car running right BEFORE you put chips in it. Focus on the basic stuff first. Build a good cake before you add the icing.
Inventor
I never looked closely before, but I ran the eBay S3 chip images I have through the disassembler again. (I have images from two different vendors, they are exactly the same.) Sure enough, on both the EZF and LH, there are Autothority copyrights on the tail end of the code.
(C)APP
The EZF has a second notice, in an unused map area (Autothority Performance Engineering).
(C)A.P.E.1991
The EZF is based on a ~428 factory chip. 227 bytes changed (incl. the copyrights). WOT map unchanged. The cruise map is 2°-10°(!) advanced over stock, mostly 6°. The 10° area corresponds with the LH fuel dump.
The LH is based on a ~721 chip. 51 bytes changed (incl. the copyright). No rev limit change. WOT map unchanged. Fuel dump at ~3/4 load in the base map, otherwise unchanged.
Maybe there are newer versions?
(C)APP
(C)A.P.E.1991
So, is there any proof AT ALL that the chips do anything but lighten your wallet?
If the only differnce is a spark change of advance, hard to imagine much more than a gain in peak torque of less than 10ft-lbs being the only expected gains.
Inventor
At least on this 1991 version, there is no WOT advance, all the advance is in the cruise map.
There is more fuel between 1400-3600 rpm @ 3/4 load (a l-o-t more fuel between 2300-2700), which should help torque, but the high rpm is stock (too rich for max hp).
Craic Head
Not sure if I'm the Mike you're asking, but I recently set it to 4 degrees advance both sides with the performance chips in there. I haven't run it in any hot weather and I'm actually thinking of dialing it back just a bit, but I'm not sure.
I'll let you know in a few weeks. I'm going to the dyno and plan to do this comparison. I've got a spare LH/EZ setup so I can swap them out in 2 minutes on the floor between runs.
There's ALL KINDS of proof...did you miss Dr. Bob's post in THIS THREAD on Tong's 10hp gain in his GT?
There are many, many before/after dyno sheets posted here and elsewhere that show gains in max Hp and Tq.
