Mobil 1 oil news/Racing oil question for the oil gurus
#46
again... most oils are fine for street use, and synthetics are good for holding up for longer change intervals, but my concern is more about the dirty oil not the condition of the oil suspending the dirt
.......... so, you will be fine with most oils ..... but, if you plan to track it, or live in hot conditions, I wouldn't touch the oils that have proven to break down at high engine temps.
#47
In my 928MS Supercharged 928, Carl has recommended using Shell Rotella 15W-40 petroleum based oil, which is a Turbo Diesel oil. He says the seals in these older cars need the petroleum to avoid shrinking and maintaining a good seal, otherwise, you're prone to get oil leaks. He says is you must use a synthetic, use a blend so the seals stay happy.
http://www.shell.com/rotella/products/tpl-pro.html
#48
Administrator - "Tyson"
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
#49
Im curios why a 40weight would be recommended when all of us seem to agree that the 20-50 spec should be followed.
#50
Supercharged
As for blends... snake oil. Just go full synthetic.
#51
Developer
Pete's car is a 16v street car. It will likely never see a race track.
Go to the 20w 50 if that makes you happy.
Just select oils that still contain ZDDP in the right quantities. The Rotella T is good, and cheap.
...and 50/50 synthetic blends are not snake oil. See Brad Penn. But that's a whole 'nuther page....
#54
Developer
Carl, I see a Formula Shell 20W-50 but not a Rotella version in that weight, just the 15W-40. Is that what you're referring to with the 20W-50?
That said, read up on the Formula Shell version, (I havent) it might also be a good choice.
#57
No, Rotella T comes in a 20w-50. It just might not be summer-enough for them to put it out on the shelf. The difference between it and the 15-40 is no worry for your application. The 15w-40 would be fine.
