928 Forum 1978-1995
Sponsored by: 928 Specialists
Question on Mounting Fuel Rails
Old Apr 19, 2009 | 02:09 PM
Elmiko's Avatar
Elmiko
Default Question on Mounting Fuel Rails
When I removed my fuel rails, I don't remember ever seeing ever the rubber buffers that are supposed to be on the 4 threaded fuel rail studs. I never actually took the studs out of the intake-they're still in place. It doesn't seem likely that all 4 would have deteriorated and fallen off without a trace. Looking at them, the upper part of the studs doesn't seem anywhere near long enough for a buffer, the fuel rail bracket, a washer, and the nut. Were the buffers always used?
Old Apr 19, 2009 | 02:17 PM
soupcan's Avatar
soupcan
I have read that only very early 87's had them, my 87 does not.
Old Apr 19, 2009 | 02:41 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Not on most cars I have seen. Not on my 89.
Old Apr 19, 2009 | 04:32 PM
UKKid35's Avatar
UKKid35
My early '87 does not have rubber bushes, but it does have thick alloy discs under the fuel rail mounts.
Old Apr 21, 2009 | 06:58 AM
oz928s4's Avatar
oz928s4
Nothing on my 88
Old Apr 21, 2009 | 10:40 AM
worf928's Avatar
worf928
The rubber buffers are only on early '87s.
If your intake has threaded studs on the fuel rail mounting 'ears' then you don't need no stinkin' rubber buffers.
