Master Thread - Aerodynamics
#31
it to a hole through the sunroof. No need for the cool suit. Just make sure
the hose is fire proof...
#33
Another immense improvement, well within our reach, is a full bellypan with Vette-style outlet fins at the rear. heinrich
#37
Owns the Streets
Needs Camber
Needs Camber
Probably never pass tech as I'm not sure if the safety guys want to see any large connections like that past the firewall.
Is that why they call it a firewall. Wall to keep the flames outta the passenger cell.
#38
the fire wall and removed the glove compartment, then I'd plumb it there and
route the hose up the passenger side A pillar to the roof.
#39
Pair of double layer fire-proof (don't want any engine compartment fumes or fire to enter passenger compartment) tubes running up the A pillar. Attach the tubing along the front A-pillar part of the roll cage.
seal between the firewall and the heater vent intake area. Seal up the
regular vents to the outside there, and then use the hole for the AC stuff to
get into the passenger compartment. Then connect that to the hose going up
the A pillar. The hose can be boxed or formed so it doesn't look like a hose if
need be.
#40
Owns the Streets
Needs Camber
Needs Camber
The hose can look like part of the roll cage.
Got it.
But don't most race organizations require sunroof closed for their events?
So the trick would be to remove seal around the sunroof and vent engine compartment out around the sunroof.
Got it.
#41
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
#42
"negative" pressure is higher, otherwise correct. The high pressure areas are at the front vertical surface (point 3) and base of the windshield (point 13) and then at the rear spoiler (point 30).
#43
I've been waiting for somebody to bring this up, although the responses so far are pretty much what I expected.
That crash had very little to do with the belly pan and more to do with the rest of the aero.
I am planning a full belly pan with diffuser for my car. The radiator will be inclined at a steep angle with a vent in the hood. There will be other venting, but nothing will go into the cockpit. As much as certain people claim that it's foolish not to run 305+ wide tires on a race 928, I'm sticking to 275-285s due to drag. It will be interesting to see how it fairs vs BMWs weighing 100-300lb less with 245-255s and Vettes weighing 100-500lb more with 315-335s.
It would be nice to see a well designed rear diffuser for our cars. I think any full belly pan should be vented and ported out the top or side of the car to release any high pressure spikes, you don't want this happening to you.
#44
I talked to Marc T. about the underbelly pan & rear diffuser. It was stored in his shop "attic" along with a bunch of other neat experimental stuff. He said that it did supply rear downforce in a goodly amount. Handling became squirrelly above X mph. The thought was that it lightened the front. Possibly adding more aero bits to the front would have helped, but I don't know.
#45
why is that? less tires being seen? thats the only thing i could see effecting frontal area and as it is, that would be fairly small. 1" lowering 10" tires, 10sq" x 2 or almost .13 sq-ft??
mk
mk
