GTS Rear Brake Calipers
Hi
Can anyone here confirm that I can bolt GTS rear brake calipers [928.352.421.03 & 928.352.422.03] onto my S2 rear hubs?
I also want to use S4 rotors with this set up.
Will I face any alignment problems.?
Thanks.
Thanks.
With the risk of stating the obvious - I hope you are fitting S4/GTS calipers at the front of the car too...
Supercharged
To build on Cheb's stating of the obvious, IIRC the stock bias valve is 18% - meaning that 82% of the braking force is done by the fronts and 18% by the rears.
Thanks guys.
I am currently fitting S4 brakes and suspension to the front which is why I haven't even had time to look at any potential rear brake set-up problems yet - which is why I asked the question.
Andrew -
Will it be OK to have 82/18% brake bias with S4 front brakes and GTS rear brakes? - Why did you post this?
Thanks.
Andrew -
Thanks.
Team Owner
the rear proportioning valve can be changed
could you please list the year and model of your car
Thanks guys.
Andrew -
Thanks.
Andrew -
Thanks.
HTH,
Alex
My 928 is the same as Alex'es - a 1984 S2 Manual. Now with front S4 Brakes and suspension. Where can the brake bias / proportioning valve be found?
Administrator - "Tyson"
The early cars have more rear brake bias from the factory. A few people have installed the early valve on S4's to increase rear bias.
Hacker, the UK early-ish cars - S2 (4.7 twin dizzy 310bhp) came with ABS as standard in 1984...
Chronic Tool Dropper
You can change the bias valve to give you more rear participation, and it will help right up to the point where the ABS needs to help you with a slipping wheel. IIRC, the ABS affects -both- rear wheels if it determines that -either- is slipping. So don't go overboard on the rear bias, especially if you regularly drive on less-than-perfect surfaces like rain-slicked roadways.
Done about 5000 miles now with this set up and it looks like the rear brakes are definitely taking more punishment than the fronts.
Not that this is a problem but I think the next time I replace the brake fluid I will switch to the 18BAR S4 limiter to put more bias to the fronts - just to see what happens over time. - Will report back.
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
