928 Forum 1978-1995
Sponsored by: 928 Specialists
PSD/Diff into S2
Old Mar 24, 2009 | 03:12 PM
Brett928S2's Avatar
Brett928S2
Question PSD/Diff into S2
Hi All
I am going to fit a PSD/Diff UNIT from a 94 GTS into my 16 Valve S2....
Can anyone tell me for definite whether the PSD/Diff will have a 2.2 ratio ???
All the best Brett
Old Mar 24, 2009 | 03:20 PM
RyanPerrella's Avatar
RyanPerrella
No its NOT a 2.2
if its an auto then its a 2.53
I have to ask WHY? you cant run the PSD diff effectively without the PSD electronic components which would be silly to retrofit into an early car.
Old Mar 24, 2009 | 03:22 PM
Randy V's Avatar
Randy V
25 Year Member
You must be new here.
You don't specify if the unit is from an auto or 5-speed GTS. They are different.
Try this site for all model year specifications:
www.928registry.org
Old Mar 24, 2009 | 03:34 PM
Brett928S2's Avatar
Brett928S2
Originally Posted by RyanPerrella
No its NOT a 2.2
Hi
Yes you can, but it then becomes manually adjustable...no pump etc....
All the best Brett
Old Mar 24, 2009 | 03:36 PM
Brett928S2's Avatar
Brett928S2
www.928registry.org
Hi
Sorry I forgot to say that mine is an Auto with a 2.35 (Non LSD) at the moment......thanks for that link ...the 94 GTS Auto had a 2.54....( I was hoping it was a 2.2)
Have to think about top speed differences now....
All the best Brett
Old Mar 24, 2009 | 03:54 PM
jorj7's Avatar
jorj7
Brett,
Garity at Motorsport SLC took the 2.2 ring/pinion from an 88 and put it in my 90 with PSD
replacing the 2.54. So it can be done.
Old Mar 24, 2009 | 04:02 PM
Brett928S2's Avatar
Brett928S2
Originally Posted by jorj7
Brett,
Hi George
I might HAVE to...as if I run the 2.54 diff instead of my 2.35 , I would lose 18 mph from my top speed at 7000 revs
If I run the 2.2 ...I GAIN 16 mph at 7000....
All the best Brett
Old Mar 24, 2009 | 04:08 PM
hacker-pschorr's Avatar
hacker-pschorr
Administrator
Hi
Silly Randy - every one knows Brett has an automatic
All the best
Old Mar 24, 2009 | 04:13 PM
jorj7's Avatar
jorj7
Brett,
I don't think I've got enough horsepower to get over 6,000 rpm, but that should be fast enough
for the roads I'm on, and that's a lot faster then I could go with the 2.54.
Good luck with your quest.
Old Mar 24, 2009 | 06:45 PM
GregBBRD's Avatar
GregBBRD
Former Vendor
You might want to ask anyone if they have tried to use a PSD in a manually adjustable mode..it might save you the trouble of doing this....only to find that they don't work, very well....Mark Anderson?
Old Mar 24, 2009 | 07:14 PM
RyanPerrella
But Greg, this is Brett were talking about here
ALL THE BEST
Old Mar 24, 2009 | 07:47 PM
Brett928S2's Avatar
Brett928S2
ALL THE BEST
Hi
Well....Paul Anderson and I will be fitting it...and HE says he has done it before successfully and as hes the FOREMOST expert on 928s in the UK thats good enough for me....
It will be manually adjustable with a bolt...
All the best Brett
Old Mar 24, 2009 | 08:40 PM
RyanPerrella
all the best
Old Mar 24, 2009 | 09:52 PM
trialattorney's Avatar
trialattorney
I run my 84 track car with a PSD manually "locked" with a bolt; not the most effective and adjustment is very tricky, but it works.
Old Mar 24, 2009 | 10:01 PM
docmirror's Avatar
docmirror
Shameful Thread Killer
At this point, I would hesitate to call it 'PSD'. The true PSD is a dynamic traction control device complete with accelerometers, wheel speed sensors, and a nice little processor to determine what needs to happen in the diff. I would say this is a LSD at best, with manual lockup adjustment.
