928 Forum 1978-1995
Sponsored by: 928 Specialists
Oil Pan Stud Kit ?
Old 03-19-2009, 02:43 PM
  #31
dprantl
dprantl's Avatar
The perfect solution would be to machine a groove into the oil pan and use an o-ring type gasket. But of course, that would be major $$$
Dan
'91 928GT S/C 475hp/460lb.ft
Old 03-19-2009, 02:45 PM
  #32
SeanR
SeanR's Avatar
That spacer/grommet or whatever you call it was interesting, but the issue I have with them is they do fall out of the gasket. We spent a bit of time trying to account for each one of them before reassembly because I didn't want one stuck in a bad place.
The current SOPG is just fine using the stud kit, as long as you don't over tighten it.
Old 03-19-2009, 03:24 PM
  #33
blown 87
Rest in Peace
blown 87's Avatar
Originally Posted by the flyin' scotsman
Another example is the possibility of a spacer falling into the oil pan with horendous consequences.
Any spacer would have to 'fixed'; like the solution Porsche has with the 32v valve cover.
And on the Porsche 32 valve cover they have shouldered bolts to keep them from being overtightened.
The shouldered bolts act like a spacer.
Greg
Quick Reply: Oil Pan Stud Kit ?
