Throttle Cable Adjustment
Sounds like the TPS is fried...........add it to next winters projects as you need to remove the intake to get at it.
Its hanging on by a thin thread and as Bill mentions it can be rebuilt but it has to be removed hence my advice to leave it until next winter when you could do a full intake refresh.
Not sure if this makes any difference if anything but the plastic piece behind the adjustment screws have broken where the adjustment screw crimps onto the throttle cable tubing. The adjustment screw is still wokring as with tightening or loosening it causes me to loose or regain the idle switch function.
![](http://farm2.static.flickr.com/1260/3353797400_b21a64cdaf_b.jpg)
I'm not familiar with the 5-Speed cable set up but you need to find which of those cables is the one that feeds the throttle plate and add slack to it. Then go back to the accelerator cable and take out some more slack until you get to the 2/3 or 3/4 pedal travel desired. JMHO.
Dwayne
Dwayne
Does that suggest that maybe I need to somehow take more slack out of the throttle cable (maybe where the actual cable gets crimped and then threaded onto the ball)?
I notice from your picture that the gap in the crimp ring and the plastic cable nut seems too large.
I haven't examined this closely but how does the quadrant function. Does the throttle cable travel more, less or the same for a given distance of accelerator cable travel? If they travel the same distance then I'm not sure adjusting the accelerator cable any more would make any difference to my situation since I've adjusted all the slack out to the point where any more slack taken out makes the idle switch not work.
If on the other hand there the throttle cable travel in greater than the accelerator cable travel by some factor then I could see how further adjustments on my accelerator travel might give me the result I'm looking for. Does that make sense to anyone but me?
Under the Lift
It's better not to have breaks in the adjuster plastic housings where you have them, but as long as the adjustment still is possible, that's OK.
That the TPS WOT trips at all is good news. When the solder joints inside the TPS crack, the trigger point moves up and eventually fails completely. Even new ones don't always seem to trigger WOT at 2/3rds to 3/4ths throttle, so eliminating as much slack as possible without taking the throttle off the idle stop is important. And as Dwayne mentions, the pedal travel limits the maximum opening. So, it's best to take all the slack out with the firewall adjuster first.
Dan
It appears your quadrent to throttle body cable is towards the tight side (using both my 928S4's as a guide)...so its possible the WOT is dying or near dying..... Both of my 928's get WOT around 3/4th throttle (pedal).... Since it is working, but with a heavy foot your still fine..
When I first got my 88 automatic it DID NOT have WOT (loose throttle cable that Bill fixed)....which just means it looses out on the WOT enrichment tables in the LH....so it stays with the standard "Cruise" maps in the LH which use the O2 sensor and is constantly in search of 14.7 AFR....so it costs you a little HP and causes the engine to run hotter and high load (Bill had this problem in an ORR and nearly overheated due to it)...
So my long winded advice is DRIVE ON....its working...then when you have some planned down time, maybe next winter...to a "Flap-O-Dectomy" and replace everything under there.....
This was a very helpful thread, I had exactly the same situation than Brian in my -84 S automatic. WOT was working only when pedal was leaning on kick-down which made car very on/off-style to drive. I could feel that car was on lean&retard side in accelaration, and chased vacuum and fuel pressure problems..
Just took slack of and car is a totally different to drive, I can feel WOT coming on and gearbox is much more responsive while dropping gears more eager without jumping on kick-down.
Every 928 owner should check this
![order](https://rennlist.com/forums/graemlins/order.gif)
