928 Forum 1978-1995
Sponsored by: 928 Specialists
FS Dual Snorkel Intake
Old 03-04-2009, 08:43 PM
toofast928
toofast928's Avatar
Default FS Dual Snorkel Intake
Dual Snorkel Intake set up, cold air is picked up in front of the A/C condenser. Made from fiberglass. Read more here: http://www.kuhnperformance.com/components.php
The snouts are fastened to the radiator shroud so you get everything in the photo. (Left and right snout have slight paint scratch from hood lip)
Will fit all years $350.00 You will need to change the condenser fan to a 12” –Also FS $75. made by Perma-Cool.
I can deliver in the NYC tri state area.
PM me if interested.
Before anyone asks the reason why I have to part with this piece is because I added two more coolers in front of the radiator. Intake air would now be preheated if I were to continue using them.
Thanks,
Tony
Old 03-04-2009, 08:50 PM
Glenn M
Glenn M's Avatar
Tony,
Are these the high flow filters?
Also, AT owners will need to modify the trans cooler (lower it) for the air filters to fit.
Glenn
Old 03-04-2009, 09:02 PM
toofast928
toofast928's Avatar
KN air filters used on my S/C. Originally designed for turbo set up. I dynoed 405HP with and without the filters so I can tell ya they are not a restriction.
Don't know about auto as mine is an MT. The do clear the A/C condenser, that is the snouts are not laying on the condenser for support, if that helps.
Old 03-04-2009, 09:21 PM
Glenn M
Glenn M's Avatar
Thanks, when I had previously emailed John he told me the auto trans cooler would have to be modified for the air filters to fit.
Glenn
Old 03-04-2009, 09:46 PM
toofast928
toofast928's Avatar
And that might be true. Need to move down the ATM cooler. I would put a heat deflector shield over the top of the ATM cooler. That way heat coming off the cooler would not be ingested into the air filters during long periods of idle.
Old 03-07-2009, 10:10 AM
toofast928
toofast928's Avatar
Lots of inquires but no takers. .........
Old 03-07-2009, 12:04 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,224 Likes on 1,254 Posts
Wow - that's a good deal.
Old 03-07-2009, 07:59 PM
dprantl
dprantl's Avatar
PM sent.
Dan
'91 928GT S/C 475hp/460lb.ft
Old 03-07-2009, 09:53 PM
Abby Normal
In Your Face, Ace
Abby Normal's Avatar
Originally Posted by dprantl
PM sent.
Dan
That is probably exactly what your car needs. Good score and I hope it works out.
Old 03-09-2009, 09:27 AM
toofast928
toofast928's Avatar
Snorkels fit N/A engine. Just remove the flex hose and connect the OEM air tubes.
Old 03-09-2009, 09:52 AM
ptuomov
ptuomov's Avatar
Default aesthetics
Don't you all love the way this thing looks?
Old 03-09-2009, 10:44 AM
Mike Frye
Craic Head
Mike Frye's Avatar
YES! (I saw it at the dyno day last year and thought it was very cool!).
Hey Tony, PM sent.
BTW- I think this would be a great setup for the '85-'86 intakes with a wye or tee at the MAF, similar to the Blackbird setup since the filters for DRs blackbird won't work in the S3.
Old 03-09-2009, 10:50 AM
DR
Rennlist Sponsor
DR's Avatar
I agree, already discussed this with John and is one of the thought processes I have for the 85-85 and 16V.
Nice setup at a great price. IMHO, One of the SuperModel guys should have already snagged this and adapted it.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
Old 03-09-2009, 10:52 AM
Mike Frye
Craic Head
Mike Frye's Avatar
HA! Too late, I just heard from Tony and it was still available. You guys can check it out under my hood at SITM!!!
Old 03-09-2009, 10:53 AM
DR
Rennlist Sponsor
DR's Avatar
BTW, don't be surprised if you catch me under your hood with a tape measure at SITM :-)
Quick Reply: FS Dual Snorkel Intake
