Lower Ball Joint Nut Failure
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
So I'm coming from a friend's house and stop for Gas. After filling up I pull out of the Gas station and make an nice wide left turn. I notice that the steering wheel is almost 90 degrees off center, WTF? Confused, I turn the wheel to the right and back to the left and then BOOM, screeeeech. Luckily I'm only doing like 10 mph so I pull to a left turn lane and stop. This is what I see:
![](https://rennlist.com/forums/members/angel84-928-albums-general-pics-picture461-img097.jpg)
The Lower Ball Joint Nut backed out releasing the joint. Doesn't seem to be any additional collateral damage so I'm counting my blessings. I normally drive the car like I stole it but this time I was just taking my time. Again, luckily.
I called my insurance, Hagerty's, and they dispatched a Tow Truck. I t arrived about 2 hrs later but the guy was a PRO and super nice guy. When he first looked at it he jokingly said the he's was gonna "F@ck my Sh*7 up" but was "gonna do some magic" for me. He took his time and used a 2x10 to assist in sliding the car onto the bed without creating any additional damage.
Once at home we used a small hydraulic floor jack to lift the car, while still on the bed, and used a tie strap to temporarily secure the assembly together. As promised, did some magic for me and he got the car off without a hitch.
Now comes the post accident inspection. Wish me luck.
Team Owner
Maybe you get away with only installing a new nut
I would consider replacing both lower Ball joints, as damage could have been done to the one that separated and if the other side is original well why not do both .
You should have the car aligned after wards
Man of many SIGs
I hope I wasn't too flippant last night when you called. I was right in the middle of a celebration and already had 6 martinis and a capirinha in me by the time you started calling. Don't sweat it man, it can be fixed. And like I said, theres a perfect fender on the lemons car. It only needs the holes drilled for the spoiler. I'm sure mike can work out a great deal for you if you turn over your old one as a core.
WOW, that sucks. Hopefully the damage was minimal. Those nuts are supposed to be single-use. Either they were re-used many times, the wrong nut was used, or it was never torqued down.
I hope I wasn't too flippant last night when you called. I was right in the middle of a celebration and already had 6 martinis and a capirinha in me by the time you started calling. Don't sweat it man, it can be fixed. And like I said, theres a perfect fender on the lemons car. It only needs the holes drilled for the spoiler. I'm sure mike can work out a great deal for you if you turn over your old one as a core. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
I am missing pg. 40-26 out of WSM.
Rennlist Sponsor
99908405902
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
![](http://www.928gt.com/images/928Specialists-COVER3-928GTcom.png)
Rennlist Sponsor
Under the Lift
The replacement balljoints (at least when purchased on a tie rod) from our 928 vendors have had a castellated nut and were drilled for a cotter pin.
[EDIT: Aw, Jeez!!! I see now it was the lower control arm and not the steering knuckle balljoint that came loose. Heck, the thread is even titled lower ball joint! Anyway, that balljoint comes with a single-use nut and is not pinned. Sorry about the confusion.]
Administrator - "Tyson"
Craic Head
![](http://members.rennlist.com/sharkskin/Pages_SA_R25-Rack-Oil_Pan-Engine_Mounts-PlateInPosition.jpg)
Man of many SIGs
During our conversation last night, Tarek mentioned that he had this same failure in the past. He also mentioned that there wasn't a cotter pin on his. maybe it varies depending on the vendor. I have some lower ball joints in the garage that are made in Germany. The brand of the bag is Lamforden Metallwaren but t he box says distributed by Brant Ainley. These do not have a hole for a cotter pin or a new nut.
Under the Lift
My original balljoints had solid locknuts and no cotter pin holes, but all the replacement tierod/balljoint combinations I have purchased from 2 different 928vendors had the castellated nuts and cotter pin holes. Regardless, I never had a problem with my stock balljoints coming loose, but I don't believe they had ever been loosened until I replaced them a few years ago. If you don't have cotter pins, checking the balljoint nuts would be something to add to the checklist when doing the annual oil change.
[EDIT - WRONG BALLJOINT. SORRY!]
