Any Motorcycle Riders Here?
#151
I too, don't wish the thread to end, but it needs contributions...
While I can't add much without questions or statements I can answer to, I have a question, which may be outside the particular thread here:
Does anyone know a business that mandrel bends tubing? I need an exhaust pipe made, for my oldest bike.
#154
Stan,
Unfortunately, every one of the local exhaust shops do not seem to use mandrel benders...... They use tubing benders, which, unfortunately, put kinks in the bends, or flaten the bends, so that the tube is no longer uniform in cross section, even to the point of creating a "D" shaped cross section. Very ugly on a bike....
#155
Kinda risky to go for a ride but I did start the KLR 650 the other day.
To much gravel on roads and the potential for snow showers.
Nice sound Bill..........6-2-6
#156
Stan,
#157
OK Stan,
Yes, I know about those; a local nationally known race biz [should I mention them?], can supply me with "mandrel bent 'U's", even in stainless, but that will not supply me with a pipe, with multiple compound bends.
I need a pipe that is called, as far as I know, a sheep's hook, with smooth transfers from one diameter bend, into another diameter bend.
There are cheap copies made of these types of pipes, but other than the initial 'hook' bend coming out of the exhaust port, the rest of the bends are pretty sharp and sudden, connected with straight sections. No swoop or flow to them.... Often not conforming to the path taken by the original, even protruding out into the wind stream much farther than wanted.... Leading to the possibility of burnt leg syndrome.... Let alone getting smashed in narrow passages...
Yes, I suppose the easiest pipe to make, would be a down pipe, I've even ordered one from Armours in ol' blighty, but it doesn't fit, they won't take it back, nor refund my money. And, it doesn't have the swoop and flow of an original pipe, rather sharp bends, and straight sections.... Useable, if it would have fit up correctly....
The end of the muffler, if I could have fit the muffler onto the pipe, would have been below ground level. And, outboard of the correct line along the side of the bike, by 6, SIX inches!!!!
Malcolm,
It's my '48 AJS, a 500cc single.
Malcolm,
#160
Brett, PM sent
#161
So, You think that you can ride a motorcycle???
Watch this....
http://www.youtube.com/watch?v=xBw0yH509lw
Watch this....
#165
Dr Jekyll & Mr Hyde
Ducati 900 SP's
First one is a stock 900 SP limited edition (Dr. Jekyll)
The second is a factory modified Superlight that is based on a 900 SP chassis... (Mr. Hyde, aka beastie) All the fairings on the modded is carbon, too many custom parts to list..
Bikes are fun..!
Cheers..!
Bikes are fun..!
Cheers..!
