What were your winter projects?
Rennlist Sponsor
Dave, Will call you tomorrow on Pro Vent hose routing and mounting. There isn't much room to it on the 85, with the wide intake, throttle linkages up front and that big *** mount for the linkages and mechanical fan (which I have deleted) but installed the electrics on that side of the radiator. I have an idea for a mount that I will run by you tomorrow.
Sorry I didn't see this reply.
Here is something that should help you. I am putting the finishing touches on a new product line using the Provent called "SharkVent". It is a complete system with everything you need to install a Provent on a 928. I have finished the 85-95 Versions and working on the schematics and details on the 78-84 versions (they use the same mount as the 85-86).
Here are a couple of pics that will help you with your install. Please excuse the crappy pics of the 86 engine, it was roasted but makes a good mockup engine :-) There is also a schematic below for the 85-86 that will help you with the plumping aspects of the install. Below that is a pic of a GTS SharkVent X System we finished last week.
There are more details concerning the SharkVent CVS on our website. Visit www.sharkvent.com or look under "Performance" then "Crankcase Venting" or "928 Specialists Kits" on our website
As I said on the phone I can supply you with the bracket or any of the items you need since you already have a Provent.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
Man of many SIGs
There is no category for "crankcase evacuation systems on your site Dave.
The Provent is there under misc. but not the whole setup as shown above. At least not where I can find it.
Rennlist Sponsor
You can now go to www.sharkvent.com , or visit our webite and look on the main page under "News" you will see a link , in "928 Specialists Kits" OR just search SharkVent and you will find them.
EDIT: Fixed, you can now also find them under "Performance" then "Crankcase Venting"
Rennlist Sponsor
I hope to have the schematics and details done on the 16V Versions later this week.
Here is a pic of the SharkVent Mount on a 16V engine.
The Next Pic shows the Provent mounted on the 16V.
Rennlist Sponsor
Dave,
Here is a Winter Project I did a few years ago and is an example of how I vent the Cam Towers. This is on my Euro S Twin Screw.
I got a little carried away (also did both sides) since I had a bunch of adapters on hand :-)
I'm still debating how to approach this. I don't have an extreme oil problem, just enough mist to keep things including the airbox damp with oil. I think I'm going to start with the baffle plate under the factory separator, and the parts that Carl offers to improve that piece. I'll re-evaluate at that point, and decide whether I need to go further. Will the cam cover caps, like the one on the far right of your last pic, work on a '78 or are those holes not threaded on early cam towers?
Rennlist Sponsor
The 78-79 uses a grommet type fitting instead of the thread in fitting on the 80-up.
Dave, I hear you. What it comes down to IMHO is how much is enough. On an NA car that doesn't blow much oil in the first place, the Provent might be overkill. Carl has me scratching my head over the effort expended to improve the separator, followed by connecting fittings from the cam towers almost directly to the airbox. Anyway, enough with the hijack, I'll call when I have some time.
D
D
Rennlist Sponsor
Photo of Wear on Tensioner Pad
Sorry took so long to get around taking picture of the wear on my tensioner pads. The car has 170,000 on it. As you can see in the picture, the chain has worn the pad down pretty good, almost to the pins.
