928 Forum 1978-1995
Sponsored by: 928 Specialists
stroker survey
Old 02-16-2009, 09:04 PM
  #31
90 S-4
90 S-4's Avatar
John,
103.4 X 95.25 = 6.40 ltr or 390 cu-in
90 S-4 is offline
Old 02-16-2009, 09:36 PM
  #32
shaaark89
shaaark89's Avatar
Originally Posted by largecar379
you must have a stroked 928 engine to participate.
be honest with this, please.
no BS, just the facts ma'am.
how many liters/cubic inches? 6.5
32V or 16V? 32
turbo-ed, supercharged, or naturally aspirated? n/a
which piston/cylinder combination are you using? (Porsche or custom pistons, over-bored w/ Nikasil, sleeved, etc) 968 nikasil
which rods are you using? (steel, titanium, SBC based or custom, etc) titanium
how is the car driven? (track only, hard street driving, or just putting around) street
how many miles do you have on this engine since installation? 10,000+_
maximum rpm's you turn this engine? 6500
have you had any rod failures? ( broken, bent, etc) no
have you had any excessive piston/cylinder wear? (skirt wear, where is it, etc) not aware
have you had any piston/cylinder failures? (broken pistons, gouged cylinders, etc) no
please answer this survey to the best of your ability. I realize that you may not be able to answer all questions if you engine has not been through a tear down since being built, and that's OK. If so, just list it as currently running with (hopefully) no issues. if you are on a second, third, or more build, just let us know what the issues were with the previous engines as they relate to the survey.
I am not interested in hp/torque numbers, intake/exhaust, headwork, or how much/little you spent on your build. I am more concerned with short block reliability issues.
I would like to put this data on a spread sheet and see just where we in the 928 community are with reliability with the various 928 stroker builds that are currently in place.
Thanks for your time---
--Russ
1 of 3
shaaark89 is offline
Old 02-16-2009, 09:40 PM
  #33
shaaark89
shaaark89's Avatar
how many liters/cubic inches? 6.0
32V or 16V? 32
turbo-ed, supercharged, or naturally aspirated? supercharged
which piston/cylinder combination are you using? (Porsche or custom pistons, over-bored w/ Nikasil, sleeved, etc) porsche 944 standard bore
which rods are you using? (steel, titanium, SBC based or custom, etc) steel
how is the car driven? (track only, hard street driving, or just putting around) track
how many miles do you have on this engine since installation? 0 (3 years previous iteration)
--Russ
2 of 3
Old 02-16-2009, 09:43 PM
  #34
shaaark89
shaaark89's Avatar
32V or 16V? 32
which piston/cylinder combination are you using? (Porsche or custom pistons, over-bored w/ Nikasil, sleeved, etc) je 104.01
which rods are you using? (steel, titanium, SBC based or custom, etc) oliver titanium
how many miles do you have on this engine since installation? 0 (dyno only)
maximum rpm's you turn this engine? 7000
--Russ
3 of 3
Old 02-17-2009, 12:28 PM
  #35
Bob Rouleau
Still plays with cars.
Bob Rouleau's Avatar
Thread closed by request of the OP.
Bob Rouleau is offline
Quick Reply: stroker survey
