Coolant color
Hello All,
I read in a recent thread that someone had the wrong color coolant, green. I am in a bit of a panic, last May I had my Timing belt/water Pump and new thermostat/coolant changed and discovered green coolant was used, should I change it asap or can it wait til it warms up outside?
The mechanic said it was Audi coolant Part # ZVW237105 so I went with it not knowing better.
Your advice would be greatly appreciated.
P.S. I have noticed a leak and figured it must be the metal contracting in this bitter cold, -28C the other night.
Thanks,
Drew.
Leakage Pics:
Thanks,
Drew.
Leakage Pics:
LOL
dont worry, anything used in an aluminum block will e fine, last i checked Audi was a huge champion of aluminum so i think your more then safe.
There is no (to my knowledge) set recipe of what makes a coolant orange, or green, or blue, its just coloring.
RELAX, your fine
RELAX, your fine
Phew!
Sorry if it was a noob question but I just want to keep my shark happy.
Thanks for the quick responses.
Malcolm, I see you are enjoying a heat wave out there....enjoy while it lasts.
Bitter cold here.
Thanks again.
Bitter cold here.
Thanks again.
That color is actually blue...or it will dry blue, if you got the ZVW coolant. I've used the ZVW coolant, for years. Works great. Also leaves really nice blue trails...to find the water leaks. The blue trail rinses off with water.
It looks like the leak is at the large o-ring in centre of coolant bridge. Fixing that would require removal of the bridge. At the same time you can replace the two small gaskets at each side of the bridge.
