16v Intake Manifold Study and Prototype
#213
Archive Gatekeeper
Pewter's not too far from Zermatt silver, would match the valve covers pretty well.
#214
Spencer I had rather hoped no one would post the pictures of the Salsbury 4850D until April 1.....but what the heck nearly everyday on Rennlist seems like April 1 .
#215
The all aluminum extruded construction and relative lightweight of the Salsbury 4850D has a lot going for it and over the years has been impact tested even simulated backfires using M80 fireworks (has integral blow off flap).....has literally withstood the test of time !
but, according to Rob, its the shape of a mailbox? would that fit??
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Jim, any pictures?
#216
Rob is not thinking outside the mailbox ... naysaying is not productive !! sometimes the simplest solutions are the best.... open your mind !! While it might LOOK like a mailbox it could in fact be the ideal shape....nice flat floor to mount to the intake flanges , curved roof to resist intake suction and pressure plus controls resonance as pressure wavse rebound off the constant radius. I predict at least a 75-100 hp improvement and the plenum is ONLY $100 !!! use two and gain 200 HP ! OR BETTER YET FIT 2 OR 4 OR 6 ELECTRIC SUPERCHARGES !!!! My god there is no limit to the incompetence of the Porsche engineers what could they have possibly been thinking ??
#217
Carl no disrespect intended for you or your intake products obviously much effort , thought , and analysis went into what you have successfully built... which also means you know how much of everything such projects require.
#219
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/883x489/johncummings_a_edited_cd70bde701bea33be28485c5a744bb61973cf170.jpg)
#220
Developer
Ah. Good information. I have not raced or flow-benched the pipe-organ, just worked on it in customer cars, etc. Always impressed me with the size of it's tubes and what I felt was a tremendous capacity for air flow.
Can you expand on what you have said? WHERE are some of those compromises that choke it down?
#221
Rainman
I could probably borrow the "T" and side tanks from a friend.
If you have a flow bench it'd be useful to post up the results, of how useful that tremendous looking intake really is.
