soon Should i pull the plugs first and add some 2stroke oil in the cilinders ?
Are there other important things to check first as not to damage the engine by a temp to run ?
I will ofcourse inspect visually the belt for a" startup" and renew if we plan on using this engine further....
Definately add some oil to the top of the cylinders as you noted. In leiu of Marvel Mystery oil, 2-stroke will at least coat everything on the cylinder walls. Add a couple spoons full to each cylinder and let it sit... for a couple days to be safe. Try to spin it by hand first...
After you can spin it by hand, check the belt tension at 0 and then rotate and check again.
Once everything moves freely without expensive sounds, and the belt has proper tension, put the plugs back in and turn it over with the starter sans fuel pressure. If everything still sounds good, push the fuel pump relay back in and cross your fingers. Good Luck!
thanks for the replys !
now i'm not sure yet about the year... think a 82-83... as the owner described. He bought the car "wrecked" as for spares for his running car but doesn't use it much so in 10 years never needed a spare item.. Car is even stocked between pallets in a hangar , so i even couldn't see it... He will free it up one of these days and transport it to my garage. We agreed to "buy" the engine after i see some life in it and all seems good.
Now about the belt... sh*t, i removed a perfectly good one from my "racer" to put a new one on it... and discarded that belt... had i know...
The other thing you will need to do is drain all the fuel out, and put a fuel cleaner in with fresh fuel, you may have to replace the pump just to get it to run.
Like a few others here I can absolutly state that some 16V motors are interference. I will be pulling my motor today as my belt jumped a few teeth and aterwards I had no compression in one hole.
lucky i still have the pump from my car... as i now use 2 "carb" pumps. So i could replace it easy if it isn't working anymore. Mine was running perfect .. till i got messing with it ...
<MORE>, please. Year and type now. Later, what you find when you get in there.
