Cam chain tensioners (32 valve only)
#31
How much are the entire assemblies? One of mine had a cracked bottom.
#32
Basic Sponsor
Brendan,
The half price sale at 928 Int is your best bet.
Roger
Roger
#33
For new ones. I haven't checked recently.
#34
Found some information on the cam chains available, it seems the STD Iwis chain was used by Porsche as original.
/Peter
IWIS is the Original Manufacture for Porsche.
We have pictured all three side by side. There is a visible and measurable difference between the IWIS chains and the Bilstein (Febi).
The difference in appearance and weight between the IWIS Racing chain and the OEM IWIS chain I cannot detect with the naked eye. Our scale is unable to measure a difference. Now there very well maybe a difference in the metallurgy. But the scale does not pick up the difference in density.
/Peter
#35
FWIW,
I had a pair of the Bilsteins that i had bought before i rebuilt my GT engine and they really looked like **** honestly. I would probably have gone with the used old ones over the bilsteins.
I ended up with the factory chain which ir either the IWIS racing or IWIS OEM chain, its much higher grade stuff and this is not a part i would skimp on. Not that i think the Febi/Bilsteins would break but i was less than impressed with them.
#36
Basic Sponsor
Peter,
Both IWIS and Bilstein are OEM to Porsche.
You pays your money and takes your choice.
I probably sell more of the IWIS racing chains than the others.
Roger
Roger
#38
Former Vendor
Sure, you just need some sort of sealant. Make sure you scrape off all the old sealant, as the Yamabond will not soften the Loctite.
#39
I tried Yamabond and it still leaked. I've got a huge tube of the loctite. Let me know when you need it. I'm not that far from you.
#40
cam chains and tensioners replacement job
How much does it cost Roger for the work to be done to our car? Cam chains,pads and labor cost at your shop. I am planning in the spring time maybe spring the car to you......ALL depends on cost.
#41
Hi.. I am about to install an original new cam tensioner assembly in 928 GTS,1993... I have a confusion as I checked the new assembly there is very less tension in it & no oil inside, the old assembly is good there is a lot of tension if we try to compress it with hands... but pads are in bad condition... How I am supposed to build pressure inside the cam tensioning assembly...I don't know if it could be a bad idea to install a new assembly without knowing if pretention is required or not ?
thanks
thanks
#42
thanks
thanks
