Fan conversion, early cars
Anyone every get this?
http://cgi.ebay.com/ebaymotors/PORSC...spagenameZWDVW
Because there is also this, which is from someone we know:
https://www.928gt.com/productspecs/40372.htm
Hmmm. The do look similar. No temp sensor in the ebay auction, nor in Carl's piece as well.
Looks like Carl's has the through-flow flaps - good for higher speed cooling.
The 928spec one seems to have all the required stuff for control however.
Inventor
AFAIK, 928 MS, and 928 Spec both use the same SPAL part#, with their own brackets, and wiring.
(928 MS into thread)
http://desc.shop.ebay.com/items/?_nk...LH_TitleDesc=1
I put a Zirgo 16" 3500cfm puller kit on mine, came with adjustable thermostat and sensor. Works great at all speeds and idle. Draws a good bit of juice but car runs much colder than with the flex fan. Think I paid $80 shipped 3 years ago.
Fit's inside the stock fan shroud with a little work.
Rennlist Sponsor
http://www.spalusa.com/fans/automate..._dualpull.html
Pretty sure Carl uses the Spal Dual 11"
We add custom water jetted (and bent) aluminum mounting brackets that bolt on to the factory mounting points. Also custom aluminum plates for the wiring and sensor pass thru on the Pre-S4 version, along with custom plug and play wiring harness. S4 has hardwire harness.
We also pre-mount brackets for our optional Aluminum Upper Fan trim and air inlet plates (see pic below). Also available are custom aluminum mounting plates for the ProVent.
However if you want to do your own custom brackets and wiring both of these are available on Ebay VERY cheap..... MUCH cheaper than even Spal sells to us unless we buy hundreds at a time :-(
Here are the links, will help save you some money if you make your own custom stuff..
Dual 11" Spal Fan $189 - http://cgi.ebay.com/ebaymotors/NEW-S...mZ370113641120
Dual 12" Spal Fan $259 - http://cgi.ebay.com/ebaymotors/SPAL-...mZ370116033452
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
![](http://www.928gt.com/images/928Specialists-COVER3-928GTcom.png)
Well, 259 + the custom pieces and work you did Dave are well worth your price. Which I believe includes the variable controller.
Inventor
Rennlist Sponsor
Yes the 12" is bigger and rests around the perimeter of the core "frame" exactly like the S4 fan housing..
![](https://www.928gt.com/productspecs/images/clip_image024.jpg)
Rennlist Sponsor
Thru Spal in small quantities they cost $299 (Retail is $449.99) , plus $18 for the pigtails, PLUS $20in shipping. Total of $337 BEFORE the mods begin :-(
BTW, on the pre-S4 we use a temp probe for one fan and the second fan uses a factory connector pluged into the original electric fan feed. Gives a 2-stage fan system similar to the S4, no controller needed.
