Cheapest Fuel Pump?
Correct they blow of the excess at the fuel distributor return it to the fuel tank. You can shim the needle to have higher system pressure like Mark did when he raced a modified 5 liter Euro 16 V with high flow heads to get it up over 400 HP at 7,500 RPM or so .
Soooo, will a higher pressure (different year) fuel pump work on my '84?
Don't need one now but when it dies and I use my friend "Search" on Rennlist, it would be nice to have a straight forward answer.
Pros - Cons of using a different fuel pump?
I'd like to know this too. The pump on my '84 Euro died and since the Euros naturally tend to run lean, I wonder if a higher pressure fuel pump would help (possibly with a rising-rate FPR).
Angel, and flint, replacing the fuel pump with a unit that can produce more PSI will not help your cars at all. Fuel pressure is simply controlled by the fuel pressure regulator in the engine bay.
If you use a higher PSI rated pump, it will do the job without any issues, you may just not be using it to its full capacity.
I bought a Bosch fuel pump for my truck and it had a bad check valve causing excessive cranking. Replaced it with a Chinese knock-off that was perfect. Just one data point but there it is.
-Joel.
-Joel.
Is it possible that a pump that puts out too much flow/pressure could overcome the bypass capability of the regulators on an LH system, resulting in too-high pressure?
