New Product: GTS Fender Flares
#31
best regards chris
#32
Rocket Pilot
#33
Do you replace the entire fender Kevin? Or do you massage the metal that is there and possibly add some?
I saw (as many did) Paul's car - it looks really good.
#34
Rocket Pilot
Hi Brendan. I replace most of the quarter, probably 85% of it. The flares I use are fabricated out of spare fenders then wheeled and shaped to a factory fit. Paul's is probably the most recognizable name that got this treatment, but we have done many others including Bill's( Iccy 928) racer that we're doing right now. Louis flares are a wilder example and very very nice in fit and finish for those who want something wider.
#35
I did my own smaller flares on the 78 body. From that, I learned that to do it properly with a larger look, you would need more time, and as you show - to add a completed fender to the area.
#36
#37
Rocket Pilot
#38
What about those DEVEK Flares? Wherer can I get more Info about them?
#39
My blue 928 was the "model" for Carl's flares. They fit fine and the gas tank lid fits fine as well. The only problem is after they were glued in place the rivets that were used to hold them in place during the gluing process were not removed. Moisture from the wheel well has worked its way into the rivets and the body work has lifted slightly. You can't see it in the photos but from within 5 feet it is apparent. I'm parting the car and if anyone is interested in them I will carefully remove them and you can have them for $225.
