New Product: GTS Fender Flares
Developer
Hand-laid fibreglass rear fender flares in the GTS model for your 928...
Adds 2.5" of additional space for wider tire/wheel combos (when measured from the stock tire/wheel outward).
Tapered construction - the mounting edge is thinner so the part will blend in to the body panels with a minimum of filler, yet strengthened in the center and the lip to add strength and ridgidity. Weighs only 5 pounds per pair.
More info here:
http://www.928motorsports.com/parts/...der_flares.php
More info here:
Owns the Streets
Needs Camber
Needs Camber
Developer
Kibort, I like the look of my racer, thank you very much.
But those flares are way to big for most.
We wanted a more subtle flare for the many requests we get for exactly that.
The body/shop/installer will add a little material to the filler flap, or trim the flare (your choice) so it stops farther away from the filler flap.
Carl this looks VERY interesting but please SHOW a raw photograph of what you're doing/did with the passenger flair and the gas tank area when you did your examples. I'm not quite sure I understood your explanation about "adding a little to the flap" Thanks!
Paul Barrera '91 $$$$4
