Pascha material on ebay.nl
http://cgi.ebay.nl/ws/eBayISAPI.dll?...m=120321358550
No affiliation. Until the recent OB thread I thought this particular color was still available at Lemans in New Zealand, but now I'm not so sure. If this is what you need, this might be a rare opportunity. I think this is the color that I originally bought from Lemans thinking it was black & white. In fact, under fluorescents it looks black & white, but when you get it under natural light there's a definite brown tone to the "white".
Good luck for whoever wants it.
Administrator - "Tyson"
Location: No where Oklahoma AKA "The Dust Bowl" In The Arm pit Of Hell
Are you sure it's 1K? I thought the Euro was close to the dollar wich would make it around $294.00. I'd love to have pascha. It just looks fast
Yeah, where are you getting $1k? If you change the domain to ebay.com it does an exchange rate conversion for you:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=120321358550
Unless it's being sold by the meter - $377 per = $1131.
I bought 4 linear meters and the guy who bought it from me says his upholsterer had to do a lot of hard work patching things together in non obvious places to get everything covered. 4.2 meters is better but Sitzklinic told me later that 5 meters was the requirement for an entire interior.
Come to thing of it, it may come down to how the material in particular was cut, and I think the one on ebay is cut better than mine. Assuming you want the pattern lined up correctly, note that the area with the densest squares in the pattern are centered on the headrest. The ebay material has that pattern far enough from the edge that you might be able to get two front seats side by side out of a length of material. That wasnt' possible with mine:
![](http://bronto.csd-bes.net/mediashare/vfsdb/frzq191y5yy84sm5l554hvyiuv4odc-pre.jpg)
Note how close the part needing to be centered is to the edge. This particular cut was very wasteful. I went so far as to use masking paper as a pattern to see how it could possibly be laid out to fit:
![](http://bronto.csd-bes.net/mediashare/vfsdb/b6d6xl6ivzpf9dlbmww2ej6zrvmqf2-pre.jpg)
The above example looks like it would fit
but I'll have to point out that this is because I shifted the patterns to the right so that the large squares were centered on the headrest, the exact opposite of what it should have been. Shift the paper one half "grid" and you'll see how badly it would have worked.
Bottom line, the ebay one looks cut better, and you might be able to yield an entire interior out of it.
Very good info and a decent buy for someone looking to do this. I've given up on the Pascha for now because I'm too far into the suede to turn back. I must say though, whoever designed those rear seats was a sick, sick person.
