OB Idle Adjustment Screw Stuck!
if it gets to loose now that you have moved it just slip a piece of rubber tubing over the head and push it tight up agains the TB base the rubber will keep it from moving
It's well oiled and I'll keep an eye on it just in case the spring decides not to hold it.
Thanks again to everyone for all the suggestions.
