Last question for like 2 weeks promise (shifter alignment - rv)
#31
Why wouldnt it of done it allready,its got 107k on it, theirs no way to stop tbf, in my opinion going in their and prying it with a pry bar is ludicrous thats what causes tbf when you start ****ing with the plates and **** leave it alone lol
#32
That's good news, dude! It means it's worth doing the timing belt and water pump and maybe it will stay that way. I'm really really happy to hear it, for your sake. ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Time to get to work!
#33
Why wouldnt it of done it allready,its got 107k on it, Cheap PO theirs no way to stop tbf Maintenance does sure seem to prevent it, in my opinion going in their and prying it with a pry bar is ludicrous Not really it is preventative maintenance thats what causes tbf when you start ****ing with the plates and **** leave it alone lol Please be Kidding
#35
Team Owner
you need to undo the clamp bolt and see if the flex plate moves also see how much freeplay the crank has with the front clamp bolt loose. Also get the rearclamp bolt retorqued, if one is tight and the other loose then your work will be for nothing
#36
Your misunderstanding the tbf wasnt checked they want alot of money for that and they never even heard of that failure,except the owner knew,im worried to have some guy mess around in their,theirs like 3 people on the planet that knows how to do that procedure properly.
#38
http://members.rennlist.com/v1uhoh/cranksha.htm
http://members.rennlist.com/v1uhoh/pinch.htm
That mechanic was trying to rip you off is what it sounds like.
#39
Owns the Streets
Needs Camber
Needs Camber
Checking for TBF is so simple that anyone could do it. You could buy a jack, jackstands, a set of sockets, and the measuring tools needed and STILL only be halfway to the $500 you were quoted. It's about an hour's work, maybe 1-1/2 if the car still has full belly pans. See these links:
The mechanic couldn't give a fark and doesn't want to bother figuring out a TBF check cause it isn't profitable like his other MTM tasks.
At least that's the remote vibe I get from him.
#40
That's very true, but you don't want to pay some idiot whose never done it try it. Once the pinch bolt is loose, if he doesn't have that measuring stick ready. Lose that check.
There has to be somebody up there that would be willing to help George with this. If I lived close, I'd help.
I doubt the car has belly pans.
13mm socket and wrenches for the exhaust.
13mm socket to get the 6 bolts off the housing
8mm hex head for the pinch bolt.
small metal ruler that has milimeters.
Torque wrench for putting that 8mm back to spec.
Done job.
me2
Done job.
me2
#41
I removed a black pan a silver pan and front spoiler to get car on these ramps that im paralized with fear everytime i look under their lol,its a shame i have to save some dough so i can get service done she will have to sit for now prob. till spring
#42
Owns the Streets
Needs Camber
Needs Camber
Black pan + silver pan = belly pans
Go to a 928 parts vendor and order a bellypan fastener kit.
Gets you a fresh set of matching screws with their captive washers that making working with the bellypan much less frustrating if the old screws and such are a mess.
#44
Damn, he's got a full set of belly pans and the spoiler. DO NOT LOSE THOSE.
Nice job.
Nice job.
#45
Then again, those pans are only used to hide dirt/oil/grime. I'll take them off your hands for $200.00 and a Jim Morehouse WSM set.
