Hi from Belgium
#76
transaxle swap from 82S to a '88 ...
so yesterday i demounted the transaxle and put in the new one... all fits so far .
- demounting the rear suspension is easy , just need extra hands to hold it as the hole setup wants to tilt to the rear once free on the jack.
( don't forget to demount the ebrake cable inside the car and pull it out )
suspend transaxle with something to the swaybar.
suspend the shafts to the rear suspension , be carefull with the shafts bolts... clean the allen heads and use a good wrench ! They stick hard for that first turn so i can imagine one breaks such bolthead... Mark your allen key so you can see that it is really all the way in the bolts head ....
- the rubber boot over the shiftmechanism is a bit difficult to push it over and back to the rear... loosen the bolt and allen pin , shift the tube out .
- that shiftercoupling sticks to the shaft... some WD40 and turn it with a key to get it loose. ( the front section is square for a bit , there you can place key and turn it a bit up and down...
Once this is away and the inside nut on the clamp , transaxle comes smoothly out with some dancing![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
Remounting went same way ... no big deal. Just be carefull positioning the inside clamp .The transaxle go's easy in far enough to place the 6 bolts and from there you easy push the 2 flanges together tensioning the bolts bit by bit around.
I had the clamp not good in position ( could not pass the allen head trough the hole ) , so you turn the engine a few degrees on the front balancer nut.
forgot my camera ... will post pics later![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
oh, some info : the transaxle weights 66 kg.
#78
![](http://www.vette.be/broeders.jpg)
#79
![](http://www.vette.be/achtertrein.jpg)
#80
![](http://www.vette.be/erin.jpg)
#81
The shark.... ![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
![](http://www.vette.be/capo.jpg)
#82
66 kg?You need a titanium torque tube! ;-) Carbonfiber is a nice choice too!A little R&D and we have 30 kg lost.
My project is a OB(1985)without sunroof with engine,transmission brakes and suspension from a 91 GT.The look must be stock and the goal is 370 HP.
Here in Germany we say"a wolf in a sheepfur!" ;-)
I hope you have a lot of fun first time on the track!
Karsten
Karsten
#83
Vey cool project Barry![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
I swopped in a gearbox from a 89GT into my -81S when I had it, a very straight swap.
You have to post a video with sound when you have the engine running so we can hear the weber on a v8 singing![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
/Peter
/Peter
#85
spaghetti time ! ( 928M headers )
![](http://www.vette.be/spaghetti.jpg)
#88
Great project. Please continue with the up dates.
#89
Newer ones with welded batterie box you must lower the rear setup.
Now i pushed it out of the way, don't know "how much" you must lower the rear suspension so one could remove the transaxle.... ? but i guess quite a bit....
no big deal that suspension work.... ideal time to clean and eventually renew the swaybar bushings !
and as i told at some points you need a extra help.
