928 Forum 1978-1995
Sponsored by: 928 Specialists
Lost lug nut key, ideas?
Old 09-29-2008, 04:02 PM
Jadz928
Jadz928's Avatar
Default Lost lug nut key, ideas?
I'm so pissed I lost my lug lock key. It appears to not be very easy to get a replacement (understandably). Esp if you don't know who made it, which I don't
The lug is internal tooth (female), key is external (male). Lug appears to have a left-hand thread on the outer diameter.
Any ideas? TIA
Old 09-29-2008, 04:31 PM
123quattro
123quattro's Avatar
Get a set of bolt/nut extractors from Sears. Pound the appropriate one on over the lock. Take lock off. Replace with standard nut.
Old 09-29-2008, 04:32 PM
Troy Barnes
Troy Barnes's Avatar
Get a metal drill bit and drill it out if you have no alternative.
Old 09-29-2008, 04:41 PM
BC
BC's Avatar
The vatos at the local used tire place got the locks off my wheels on one of the 928s in about 30 seconds each wheel with a hammer and screwdriver. SO its obviously somewhat possible. It looked WAY too easy.
Old 09-29-2008, 04:48 PM
Bob in Socal
Bob in Socal's Avatar
Default Harbor Freight Tool Lug nut remover socket
10 bucks, ask me how I know...
Old 09-29-2008, 05:18 PM
bigmac
bigmac's Avatar
50 cal armor piercing round is fastest way. Good luck.
Old 09-29-2008, 05:29 PM
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
When all else fails we use a hole saw but you need to be careful and stop before you damage the wheel much.
Old 09-29-2008, 05:38 PM
Jadz928
Jadz928's Avatar
Thanks folks. Lots of options here. I'll start out at Sears or Harbor Freight, then go from there.
Old 09-29-2008, 05:41 PM
Randy V
Randy V's Avatar
See this thread:
https://rennlist.com/forums/928-forum/398728-need-a-wheel-lock-socket.html
I disclose the remedy for mine on page 4.
Old 09-29-2008, 05:57 PM
heinrich
928 Collector
heinrich's Avatar
yes Randy, I recall that one
Old 09-29-2008, 06:18 PM
Jadz928
Jadz928's Avatar
Randy,
Thanks. Looks alot like this one. Will find out this eve.
Old 09-29-2008, 06:21 PM
Shark Attack
Shark Attack's Avatar
call your local salvage yard. they will tell you how to get them off with out keys
Old 09-29-2008, 07:07 PM
michael j wright
michael j wright's Avatar
Local auto parts stores normally carry a socket for just such problems.
Old 09-29-2008, 07:20 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,487 Likes on 1,399 Posts
when you buy new locks get them from the dealer they also have a master set that the mechanics use for security lug removal, its for the factory locking lug set
Old 09-29-2008, 08:03 PM
Randy V
Randy V's Avatar
I recommend removing the locks and tossing 'em. Replace with standard lug nuts.
How many times have we heard that someone's wheels were stolen?
In all the years I've been here I'd say zero.
Wheel locks are much more trouble for the owner compared to the protection they provide.
Quick Reply: Lost lug nut key, ideas?
