928 Forum 1978-1995
Sponsored by: 928 Specialists
Ran fine then no start out of no where???
Old 09-29-2008, 08:10 AM
JD928_S4
JD928_S4's Avatar
Shark Attack and Mrmerlin,
Yea I hear ya about the car possibly frying someone else's LH, I'd be fine sending mine to someone for them to try, I have actually sent my LH to John @JDSPorsche before about 2 years ago when i was having another no-start problem. Turns out it tested fine and although I thought the injectors were being held open, actually the fuel pressure regulator had ripped and fuel was pumping into the intake via the vacuum lines.
Jacob
ps Mrmerlin your car looks great with the rear wing delete
Old 10-01-2008, 09:02 AM
JD928_S4
JD928_S4's Avatar
Hey guys just an update. I duno if this helps but the car has been sitting since saturday night, and last night (tuesday) I tried starting it once. It actually fired a few times like when it first died. Thanks again everyone!
Jacob Duffney
Old 10-01-2008, 09:09 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,498 Likes on 1,407 Posts
Jacob thanks for your kind words, but the wing is still in place.
If you ask you will find someone willing to test you parts on their car, it just involves might involve some shipping and then you can rule out defective or working parts without wasting too much of your time or money
Old 10-01-2008, 10:21 AM
JD928_S4
JD928_S4's Avatar
Sorry Mrmerlin crappy LCD screen here at work doesn't do darks so well lol... I am more than willing to ship both the MAF and LH both ways... I was wondering if anyone out there would be willing to try them out for me?
Regards,
Jacob
Old 10-01-2008, 06:05 PM
Hilton
Hilton's Avatar
If you take the airbox off, what's the condition of the 3-pin plug from the crank position sensor (top centre of the bell housing)? Could be a crack in the connector there with loose wire causing the problem (happened to mine - they crumble to pieces with age).
Regards,
Jacob
Old 10-03-2008, 11:07 PM
fraggle
fraggle's Avatar
I had a short in the crank position sensor wires that intermittantly killed my car, took forever to track down.
Old 10-04-2008, 03:13 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Hey JD if you update your profile you could add your position on the planet.. Where are you now???
Old 10-25-2008, 01:40 PM
JD928_S4
JD928_S4's Avatar
Hey guys a lil update..
Ive been so busy thanks to my grad mid terms which have been tons of fun. I have had the car on a battery tender and havn'[t really looked at it since a few weeks ago. I tried jumping the fuel pump relay which definitely works and I absolutely have spark. I havn't mentioned that before the car stopped working I would have trouble and it wouldn't start in the park selector and I had to move it to the neutral cog. I havnt gotten her to do anything except crank over except today after sitting for a week or two it started first try and ran for 2-3 seconds then shut off like before and just cranks. I have a suspicion that its not the computer or the maf but something else. Thanks again for any info.
Jacob Duffney
Old 10-25-2008, 02:42 PM
Leon Speed
Leon Speed's Avatar
Why do you think it's something else?
Old 10-25-2008, 04:29 PM
JD928_S4
JD928_S4's Avatar
Well Im not sure how the LH goes but I got the impression it would act funny then be dead because the chip would fail. And same with the MAF act funny. Before it died that one day it was running perfectly. Today when the car started for the 2-3 seconds it did it sounded as strong as ever and then like someone turned off the key. It seems like a switch somewhere is like acting up either off or on now but when it first broke down it was like a switch was off-on-off-on-off as tho it wanted to run but was being held back. I duno just a thought.
As always thanks again
Jacob
Old 10-25-2008, 05:18 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
So, when you jump the fuel pump relay (pins 30-87), can you hear the fuel pump running even with the key off and after it fails to start.
Old 11-02-2008, 05:30 PM
JD928_S4
JD928_S4's Avatar
Bill,
When I tried this I realized that I couldn't hear the fuel pump, I took off the cover and gave the pump a rap with a wrench and it started buzzing immediately. It seems like the brushes are bad, when I rap on it while running the pitch changes but it still does not sounds nearly as loud as it did when the car was running. Even when the pump runs I cannot get the car to start it still just cranks. If I have the fuel pump jumped and running, under the hood on the passenger side fuel rail it seems like I hear a flow, there are no leaks and I don't smell gas but I hear fluid pumping, is this fuel pumping through a return line? or is something worng? Thanks again guys.
Jacob
Old 11-02-2008, 08:09 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
yes its fuel pumping through the lines the fuel that isnt used on the first pass gets rerouted back to the fuel tank for another go around.
One word of caution dont hit, drop, hammer, grab with pliers or otherwise do anything to the fuel pump.......... any kind of metallic hit on the side can either cause the internal magnets to crack or shatter and you can also damage the aluminum housing and cause a leak
Old 11-02-2008, 11:24 PM
Leslie 928 S2
Leslie 928 S2's Avatar
temp 2 sender
Old 11-03-2008, 09:23 AM
JD928_S4
JD928_S4's Avatar
Leslie,
Thanks for the idea but I replaced the temp 2 about 2 years ago... what is the chance it broke again?
Jacob
Quick Reply: Ran fine then no start out of no where???
