New Blood, Old Shark
Hey Everybody,
I recently aquired one of those fine Porsche 928's everybody keeps talking about. Info:
Year: 1980
Model: 928S, European
Color: Green....ish?
Here are some pics.
I got the car from a mechanic whose wife didn't want it around, so it was in running order. It looks like the engine was overhauled (no papers) and it sounds absolutely beautiful. If you'll notice, the air hoses and windshield washer assemblies are missing. This old gal needs a bit of work, but most of the hard stuff was taken care of for me. I'm excited about getting to learn how to work on a car. List of things that need attention:
Dash Lights (no illumination when lights on)
Speedometer & Tachometer, Speedo is intermittent failure
Shifter is very, very loose. (priority!)
Hood Stops, where can I get these? the little round plugs...
Throttle Body Springs
Foaming on Hood and Battery Cover
The thing is a monster to drive, my first luxury car. Unfortunately I already sunk $1500 into it for a cracked rack & pinion, alternator, hoses. A workshop did the labor. And yes, I know, racing interior *shudder*.
![](http://img375.imageshack.us/img375/2197/dscn1364pi5.th.jpg)
![](http://img388.imageshack.us/img388/5262/dscn1365gg8.th.jpg)
![](http://img388.imageshack.us/img388/639/dscn1366dw2.th.jpg)
Year: 1980
Here are some pics.
![](http://img388.imageshack.us/img388/5739/dscn1367xe6.th.jpg)
Cottage Industry Sponsor
Congratulations, and welcome to rennlist!
You have a petrol blue shark with the extremely rare (at least in the US) PASCHA fabric.
This fabric is so rare, you can no longer get any for repairs, and some people would sell the shirt on their back to buy a set.
So, keep them in good condition, or put them in an air conditioned sturage to preserve them for future generations to look at. Oh, and search for "Pascha" here on this board - you'll find many discussions about it.
The first shark I ever drove myself was this color combination. It was a one-owner 78 Euro with Automatic, retrofitted side moldings, and about 180k miles. VIN 0166. I will never forget...
those little rubber hood stops u r lookng for can also be found on late 70's early 80's VW rabbits so hit the wrecking yard or your local VW dealer lots of 928 small parts were used on other european cars the brake pads on your early 928 are the same as used on some later volvos keep your wits about u at the wrecking yard and save yourself some cash and always check here before u buy the ppl here know the deals good luck i'm jelous i love your car colours
paul with 4 79 928s
paul with 4 79 928s
The "loose shifter" is probably the "ball cup" for which you can also search on this forum. It's inexpensive parts-wise but isn't the easiest thing to get to (underneath the car above the torque tube).
Suggest going through the fuse panel (beneath passenger footwell) and replacing all fuses if not cleaning connections, may clear up some electrical issues.
Looks like a good basis for a solid shark, congrats!
Craic Head
Hey Everybody,
Year: 1980
Here are some pics.
Year: 1980
Here are some pics.
Dash lights: Check the dimmer wheel with a meter. They often go bad, you can even bypass it since it's usually turned up all the way anyway.
Speedo/tach: Get used to 'tapping the pod' or look up the fix that I think Dwayne posted.
Sloppy shifting: If it's front-back it's the forward shift ball cup. If it's side-side it's the rear shift coupling. Check/replace shifter bushings under the boot as well. Also (although it doesn't affect shifting per se) you'll want to check the release arm ball cup. All of these have bushings that wear out over time. Relatively inexpensive fixes that will TRANSFORM your shifting.
Foam for under hood: Contact Rob Budd at 928leathershop
Next add the following to you bookmarks/speed dial:
928 intl, 928sRus, 928 Motorsports, 928 specialists (not necessarily in that order
Good luck!
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Woo, good advice. I guess I'll hold onto the interior for a little bit :P
I just pulled up the shifter boot to see why it was always stuck to the right position, between 4th & 5th, and it isn't the springs. From what you said, I'm guessing both shift ball cup and the rear shift coupling. There is a lot of play in both. Is it possible the entire assembly wants to stay rotated for reasons other than the rear shift coupling?
I'll head out for the dash lights tonight, play with the fuses and the dimmer a bit. Thanks for the bit on 928leather, I'll have to get foam from them. I forgot to mention the A/C being not cold, and the idle is jumpy until the car gets warmed up.
